Frequently Asked Questions (FAQ-U)
Old Dec 22, 2005 | 02:37 PM
  #121
Metal Maxima's Avatar
SHIFT_om nom nom nom
Originally Posted by chechboy1
I'm sure this has come up in these forums but I can't find it.
Look harder.
Supercharge/All motor forum, maybe?
Old Jan 7, 2006 | 05:15 PM
  #122
5spd2000SE's Avatar
Blown MAF?
I have a 2000 SE that I put a K&N filter in two days ago, and today I started the car and it had the SES light on and was shaking pretty badly. From the FAQ's, this definitely sounds like a blown MAF, assuming the SES light comes on when this happens as well. So, I plan on taking it to the dealer I bought it from for the extended warranty (Chevy dealer) to have it replaced, but I am going to put the OEM filter back in as well. Anything else I need to do so there's no way to tell that there was a K&N in there? Also, will the ECU need to be reprogrammed? Part of the reason I'm taking it to the Chevy dealer is I don't have to pay the $100.00 deductible for the extended warranty, and I also work at the same dealer, so I'd prefer to take it there. Any reason that I would need to take it to a Nissan dealer? Also, will it hurt it to drive it? Thanks in advance.
Old Jan 9, 2006 | 06:12 PM
  #123
irish44j's Avatar
retired moderator
Timing Advance *facts*
so much misinformation flying around in this thread (the one I posted this in originally, that is)...so here's some facts:
1. Timing can be advanced to 17deg on the 00, 18 deg on 01 (IIRC), and 20 on the 02-03. It WILL "stick" and won't change back. That only happens in 4th gens.
2. It can only be done with the consult 2 tool. It takes 2 minutes to do, and is not complicated.
3. When getting it done, make sure to get the idle reset.
4. Most dealers won't do it "on the books"....best bet is to bribe a tech with some cash to do it out back of the shop.
5. It has not been provent to increase actual horsepower. The main benefit that everyone notices is a smoother engine tone and quicker throttle response. Don't consider this a "power" mod, but more of a "quickness" mod.
6. It will not kill your knock sensor any faster than usual, especially if you use premium gas. I have had NO knocking since my advance, except for sometimes when I dump mid-grade in for long road trips to save a few cents.
7. It is more noticeable on the 00-01 than on the 02-03. Don't ask me why....me (00) and soonerfan (02) had ours done at the same time. Mine was VERY noticeable, his was just a little bit.
8. you may get more knocking if you are at higher elevations (up in the rockies, for instance) because of the thinner air. Your car may be set stock to 14 or 13 degrees stock, rather than 15 like most, to compensate. Advance it 2 degrees and see if you like it....don't go 13 to 17 IMO.
Old Mar 27, 2006 | 11:55 PM
  #124
t0mmyr's Avatar
Originally Posted by ms.thicknes
I have the 2k1 ESM....and these are the Jack points that nissan recommends for the Maxima....enjoy
i can't see the pictures, i just used 4 points of my frame today to jack it up
Old Jun 4, 2006 | 10:43 AM
  #125
irish44j's Avatar
retired moderator
PEOPLE -
This thread is for posting ANSWERS to Frequently Asked Questions.
This thread is NOT for posting your own quesions!
Old Jul 6, 2006 | 09:34 AM
  #126
maximadriver198's Avatar
I having some problems with the my 2000 max. I'm thinking that there could possibly be a problem related to the stage 1 nismo clutch that I put in 3 months ago. From time to time, I will have problems putting the car from neutral into first gear or from neutral to anygear for that matter. It just started a couple of days ago. It only happens after I first start it up. When it does happen, I have to turn the car off and move the shifter into first and then start the car. Any ideas from anyone? Or can anyone tell me if a worn clutch could be the cause of my problems?
Old Jul 6, 2006 | 09:47 AM
  #127
DrKlop's Avatar
Driving is the next best thing
as I told you in a different thread. You can not ask your questions anywhere you like to. Please delete all 4 or your posts you have made so far. I will be forced to ask the admins to ban you if you will not do so.
Just so you know, if you will get banned, your IP address will also get blocked, and you will not be able to register under a different screen name.
Old Jul 7, 2006 | 09:31 AM
  #128
WMP's Avatar
WMP
I didn't see anything like this under Lighting; this is one of the best HIDs reads I have seen:
http://www.intellexual.net/hid.html
Old Oct 18, 2006 | 10:33 AM
  #129
Puppetmaster's Avatar
How do I check for bad ignition coils?
http://forums.maxima.org/showthread.php?t=451830
Credit: bigfatty
Old May 3, 2007 | 12:00 PM
  #130
Where is the IACV located?
IACV = Idle Air Control Valve
Credit: gooroo and my FSM
Mar 12, 2020 12:06 AM
-ReLLiK-
Apr 29, 2016 06:25 PM
jfl330
Sep 4, 2015 01:44 PM
Johnny9595
Sep 3, 2015 05:18 AM
