MAF cleaning
Old Feb 2, 2005 | 01:52 PM
Charliejag's Avatar
MAF cleaning
Has anybody cleaned their MAF? I didn't want to replace it just yet, so I decided to. The hardest part was getting the driver bit to get the two screws out. Its a star with a post in the middle. Anyway, I used a vacuum cleaner and forced air through the sensor reverse of the normal intake flow. This worked pretty well, the hesitation through 3500-3700rpm is all but gone. Has anybody done this another way?
Old Feb 2, 2005 | 02:34 PM
Sizzo718's Avatar
I've heard of very bad outcomes from other org members as a results cleaning the MAF. Don't mean to scare you but I thought I'd let you know.
Old Feb 2, 2005 | 03:36 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i cleaned my old maf with electronic parts cleaner a few times and it still functions. i purchased a new one because of the updated design. i cleaned it a month ago and its still running fine. the two bits are security torx in either size 20 or 25. i pulled the sensor out of the tube, sprayed it lightly then allowed to dry for a short while.
the reason i used ep cleaner is that it is safe on plastic.
Old Feb 2, 2005 | 03:52 PM
Kiosk's Avatar
like he said, use the proper electronic parts cleaner, use common sense and you wont have any problems....
Old Feb 2, 2005 | 04:57 PM
Charliejag's Avatar
FYI the bit is a 25
Old Feb 2, 2005 | 07:09 PM
I30swimmer's Avatar
new MAF sucks.. car was faster with the old version
Old Feb 2, 2005 | 07:23 PM
fornimage's Avatar
Yeah, I used throttle body cleaner and my ECU got messsed up some how. Got it replaced under warranty.
Old Feb 3, 2005 | 05:22 AM
sloppymax's Avatar
define faster? did you run at the track to compare or using a butt dyno? my car is noticeably more initially responsive with the updated one. i felt no gains except the response.
Old Feb 3, 2005 | 05:47 AM
MrPoisse's Avatar
is changing the sensor enough to negate the "common" problems related to the MAF or I have to change the whole unit?
I figure changing the sensor + cleaning the unit would be a good compromise
Old Feb 3, 2005 | 07:26 AM
Ammi's Avatar
350 Detroit Muscle
you don't need to clean the new MAF unit
Old Feb 3, 2005 | 07:31 AM
MrPoisse's Avatar
my point was changing the sensor for a new one + cleaning the unit (I keep the old one and clean it)...
or is it impossible to change the sensor without changing the whole unit???? I might be missing something here.
the MAF it self, is it only the little sensor you unclip than change than clip back in? or is this the MAF sensor that is clipped to the MAF ????? this is getting conMAFusing :P
TallTom
57
Oct 14, 2025 05:16 PM
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
