5.5gen losing oil
5.5gen losing oil
I've recently noticed that I'm losing about a quart every 2k miles. Nothing on the ground. Anyone else run into this yet? I know that I have about double the mileage of anyone else(101k), but I figure this can't be unique to me. I'll be changing my coils and plugs in another three weeks so I'll be able to tell if it's blowing out my exhaust, but I'm curious if any of you have had the same problem and know of another possible leak.
Wow that is alot. Go order some free sample bottles from Blackstone Labs. Send in a sample + ~$19 and request they email you the results. Mention the oil usage and they might come up with some causes based on their analysis.
I know it needs a good scrubbin' inside at 100k (just starting to show a little varnish), but still don't see how it would tell where it's leaking. I'll open it up here in a month and post both pics and results. I'm sure it's a gasket somewhere... well, at least I hope it's not the rings! If I have to rebuild the top end on a weekend, then so be it. I'll have to find a local orger w/ a good garage. I'll repost after I find the cause.
Another dumb question: I know I have to change the PCV. Could that have an effect? Causing it to blow oil out the tail? I say it doesn't blow smoke, but, to be honest, I'm in it while it's on. If that's a possibility, I'll change it ASAP.
They can't tell you EXACTLY where it's leaking. ie... #4 cylinder ring....front/rear main seal. BUT since you mention it's not leaking on the ground, it indicates an internal problem. And since you can't peer inside your engine the next best thing is to get the oil analyzed. From the oil, they can tell you if you have excessive ring wear, blow by, that might POINT you in the right direction.
You can look inside the coolant, dipstick and inspect the plugs yourself.
My 2k2 uses about a litre (~quart) about every 5k km (3k mi). Like in your case there are no obvious leaks and the tailpipe is clean.
The consumption has been pretty consistant though. I'll wait until the car is almost off powertrain warranty and get the dealer to look at it since the car runs well anyway. BTW I use Mobil 1 5W30 too.
You buy new? Use synthetics from the 1st oil change? If yes, you might not have allowed the engine to break in 100%.
just for reference....i lost approx .35-.50 quart of oil every oil change (4k miles)....this was for the 1st and 2nd oil changes on my car....i'm on my 3rd oil change (bought the car used)....no leaks on the ground or in the engine bay...I will moniter how much oil I lose on this next one....i thought that was kinda weird but i'm whatevers with it....since its still not over half a quart.....btw i have 35k on the ODO mobil1 synthetic 10w-30 every 4k
05RLS2
Apr 14, 2016 11:49 AM
knight_yyz
Nov 1, 2015 01:34 PM
