how do i reset my ecu?
Old Apr 29, 2001 | 03:33 PM
ohboiya's Avatar
ecu search in 5th Gen or gen'l discussion provides no results ...
is it really as ez as disconnecting my battery 4 an hour?
Old Apr 29, 2001 | 05:47 PM
UMD_MaxSE's Avatar
Got Bent?
yup. just unhook the battery for like an hour. Then, start up the car and let it idle until it reaches normal operating temperature.
mdeal's Avatar
That is the easiest thing to do: disconnect for 45 mins~1 hr. However, the ESM describes a longer process where you stick a screw driver in its brain and do some stuff. I don't know if the two end up with the same results.
Old Apr 30, 2001 | 05:15 AM
bad2rock's Avatar
What is the addvantage to reseting your ecu??
Old Apr 30, 2001 | 08:42 AM
maxedout1
I'm about to install my intake should i reset my ECU
Old Apr 30, 2001 | 08:49 AM
UMD_MaxSE's Avatar
Got Bent?
can't hurt.....the only thing you will have to do is reprogram your stereo presets and the clock.
Old Apr 30, 2001 | 01:55 PM
greggmax's Avatar
What does resetting the ECU do? Can it hurt the car? Why isn't it part of a recommended service?
Old Apr 30, 2001 | 02:25 PM
The New CLIMAX's Avatar
On the 5th gen there is no Screw driver slot, so ther only true was to have it reset
is throught a consult. but you can kinda reset it by disclonecting the battery terminal.
gigabyte
Jan 6, 2017 06:05 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
220k+ A32
Sep 22, 2015 03:08 PM
cruce91
Sep 20, 2015 10:23 AM
Colossus
Sep 9, 2015 05:46 AM
