ground points
Old Feb 8, 2005 | 11:10 AM
smoon629's Avatar
ground points
this is the umteenth time this month that hyper ground wires have come up, but i need some help. i bought a hyper ground kit off ebay and im not too sure what to do now. the "instructions" are a bit vague. it came with a main connection plate that all the wires got bolted on to. this plate is then connected to the negative terminal. but one of my questions is, where does the original negative clamp go now? i def need some help. thanks
Old Feb 8, 2005 | 11:17 AM
Max_Vader_2K's Avatar
Which one did you get, I saw one but I did not know what gage wire it was using.
Old Feb 8, 2005 | 11:20 AM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
the main negative terminal is the neg on the battery, from there it spiders out to the neg on the key points around the engine bay....
bladerunr's Avatar
Not exactly sure what you're asking but here goes: once the plate is bolted to the negative terminal of the battery, you bolt each of the wires to major engine components, such as the engine and tranny. Check these sites out.
http://www.cardomain.com/memberpage/442543/16
http://www.cardomain.com/memberpage/313259/10
Old Feb 8, 2005 | 01:00 PM
smoon629's Avatar
i bought this one: http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
see how there's that round connector plate that all the wires are connected to? where do i connect that? it says to take off the negative wire and connect the plate on to the negative terminal. i understand that much, but what do i do with the negative wire that i just disconnected?
Old Feb 8, 2005 | 01:54 PM
My_first_maxima's Avatar
somehow you are going to have to find a way to connect that to the rounded plate. I just finished making my own kit. I have 20 pictures and all the instructions and material parts list but I am having problems creating a cardomain site. But if you want to see what i did drop me an email address.
Old Feb 8, 2005 | 02:48 PM
nailz420's Avatar
there is an aluminum terminal that goes on top of the negative post, an aluminum post with a hole, and the round brass thingie that goes on top of it. The negative battery terminal goes on the aluminum post.
ow, and irish44j: your home made kit sucks ***
Old Feb 9, 2005 | 04:53 AM
SoonerFan's Avatar
Cletus
i hope you are kidding...cause it does the exact same thing as the "fancy" kits everyone else is selling
Old Feb 9, 2005 | 05:00 AM
tdogg169's Avatar
I bought my kit from matt. check out the link. he hads grounding points on this page too.
mattblehm
Old Feb 9, 2005 | 08:45 AM
nailz420's Avatar
Thats what the smiley is for. Irish plugs his kit in every grounding thread, so I thought he might see this
Not exactly. It may do the same thing but how well? There is a good article on tprmag.com http://www.tprmag.com/issue/8/8_elec_stab.shtml
here's a quote from page 2:
"The common ground point should NOT be just a bolt where lugs from each device are stacked in top of each other. The contact patches between the lugs create their own resistance and ground problems. The very best way is to bolt a short piece of copper bar near the battery to the frame. Connect the copper bar to the battery with a heavy duty ground strap. Drill and tap the bar for each ground return."
This is the same as the round brass thingie that collects all the ground returns on my "fancy" ebay kit. Apparently its not just a gimmik. Besides that your kit is probably the same as any other one, for the exception materials used (bigger wire guage, purity of the copper in wires, contacts' material, shielding, etc.). Btw, you gotta put your grounds UNDER the stock grounds.
Here's another quote from the same page: "So if the ignition system is adequately grounded no amount of more grounding can do any good.". That I DO NOT agree with
Old Feb 9, 2005 | 09:03 AM
SoonerFan's Avatar
Cletus
my kit grounds THE EXACT SAME way your does and im not going to beat this argument to death again
my03maxima
Jul 28, 2024 07:40 AM
gigabyte
Jan 6, 2017 06:05 PM
magiconthetire
Oct 26, 2015 09:03 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
