Rear Brake Help QUICK CAR ON JACK STANDS
Old Feb 8, 2005 | 05:30 PM
Zog's Avatar
Zog
I've got my back end jacked up, and the new pads on, but when I try to put the caliper back on it hits the little nub on the back of the inner pad and won't go over the top ? ? Any suggestions ? ? ?
Old Feb 8, 2005 | 05:34 PM
MaximA_GrudgE's Avatar
Correct me if I'm wrong someone, but don't you need a tool that will like sort of space out the pads/caliper? Or was that for the rotor? Sorry for not being REAL helpful, been a LONG time since I messed with a Maxima.
Old Feb 8, 2005 | 05:35 PM
Zog's Avatar
Zog
tool to turn the brake cylinder, that's taken care of, the entire assembly is hitting the little nub on the back of the new pad
Old Feb 8, 2005 | 05:44 PM
Zero Deuce SE's Avatar
The piston has to be turned to the point where the pads will sit within the notched area. That way they will be fully seated. If you need any further help, let me know.
Old Feb 8, 2005 | 05:54 PM
SkoorbMax's Avatar
As mentioned, just twist the piston a bit more so that one of the grooves in it goes over top the "nub" (I like to call it a nipple) on the new rear break pad.
Old Feb 8, 2005 | 06:36 PM
Kevin's Avatar
turn the cylinder so that hte nub lines up with the groove.
Old Feb 9, 2005 | 05:30 AM
Zog's Avatar
Zog
Yep, I got it. THanks guys.
Lakersallday24
Jun 16, 2019 01:35 AM
Huttig2009
Sep 25, 2015 03:31 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
egali045
Aug 16, 2015 01:19 PM
RealityCheck
Aug 5, 2015 06:18 AM
