6th gen brakes in 5th gen..GOOD news and BAD news
Old Feb 16, 2009 | 06:29 AM
  #121
spencediggy's Avatar
It worked for me on 20"s rims and 18" OEM rims.
Old Feb 16, 2009 | 08:01 AM
  #122
ghostrider17's Avatar
I've got abt. 5k+ miles on my 6th gen setup, and so far I'm pleased.
not a dramatic improvement - but I think, as has been stated: more heat dissipation = longer life of the rotors & pads, w/ less material deposit.
Anybody experincing any ABS anomalies??
I have seen my ABS kick-in a bit early on heavy braking scenarios, but nothing to be concerned about....just weird.
Now if I could just get RID of that annoying squeal coming from my REAR brakes!!!!
This upgrade TRULY IS the only cost-effective braking solution for our cars!
Spending $3-5k on racing setups is just plain impractical for a daily driver.
to Irish & everyone else who take the time and effort to post-up mods like this, that benefit us all!
gr
Old Feb 17, 2009 | 11:32 AM
  #123
AEMAXIMA01's Avatar
Well, now it seems like my brakes aren't the issue. I'm now leaning towards the wheel hub/bearing as to what's causing the noise. But I will definitely keep this mod in mind for when I have to do brakes in the future! Lots of good info in here!
Old Feb 17, 2009 | 11:55 AM
  #124
Puppetmaster's Avatar
Originally Posted by viperboy
Hey Irish, I followed the link in the thread about SS lines and it didn't take me to the right thread. I am looking to get new RTP drilled/slotted rotors and pads from AuToMaX_95 and I wanted to know about the SS lines. Would I need the SS lines for the 6th gen to make it for on my 02 SE because I'm looking to get the 6th gen calipers as well with AuToMaX's rotors and pads. Need a little help, thanks!
You don't need to use SS lines with these brakes. I'm using stock lines on mine. And like Josh already said, just get some nice blanks. I have the RTP blanks and they have been great.
Old Feb 17, 2009 | 11:58 AM
  #125
Originally Posted by irish44j
trying to find it....
btw, please please please do not get slotted and drilled rotors...I mean, unless you like quicker pad wear, more braking noise, and a good chance for hairline cracks in the rotor face. stick to blanks.
Is this the link you need?
http://forums.maxima.org/5th-generat...56#post3102256
Old Feb 17, 2009 | 12:35 PM
  #126
vball_max's Avatar
Where did you see or hear that you needed SS lines? Just curious as to what the reasoning would be.
Due to the upgrades from a mechanical advantage stand point, there should be less pressure in the lines to get the same amount of braking force with the 6th gen calipers. So I would think the stock lines should be fine.
Old Feb 17, 2009 | 02:54 PM
  #127
viperboy's Avatar
I wanted to upgrade the lines. I know you don't have to but i would if i was doing a brake upgrade anyway.
Old Feb 17, 2009 | 04:18 PM
  #128
Revs2Hard's Avatar
BARF
I got the drilled and slotted rotors and this is not my first set. I have never had any problem's with mine cracking. The answer to this is dont buy cheep rotors, I got mine from automax. My car dosent have alot of noise or vibrations. I love it and I wold recomend it to everyone who auto-x's.
Before
After
Old Feb 17, 2009 | 08:06 PM
  #129
AltiMaxima2000's Avatar
Monroe brakes and rotors all the way around installed last week.
Much improved performance.
Old Feb 18, 2009 | 04:29 AM
  #130
vball_max's Avatar
Good luck with those.....Please let us know how long that improved performance lasts.
Old Feb 18, 2009 | 08:21 PM
  #131
turbomirage's Avatar
After warping my stockers multiple times and rolling over the 100k mark, I decided it was time to upgrade the brakes with the 6th gen's once my pads were gone. I got the rotors slotted from automax and picked up the calipers from car-parts.com for $35 each from an '06 Maxima w/9000 miles on them.
I opted to just use a set of factory pads.
The install was a complete bolt on, the factory '02 17" rims fit without spacers (barely but they fit). The first test drive was a bit scary, there was a bad vibration in the steering wheel while braking, any speed above 40 mph. I re-inspected my install and torque specs and found the new slotted rotors were way out of specs. I turned them both (both back sides where out-of-round) and re-prepped them. Reinstalled and it test drove great. They feel great and require less initial pressure to start braking.
I also weighed them and found the rotors were both about 5.5 lbs heavier than worn out stockers and the calipers/brackets were around .8 lbs heavier each....so about 6.3 lbs a side heavier, which you can feel a little on accel.
Fronts stock
Fronts with 6th gen BBK
Old Feb 18, 2009 | 11:07 PM
  #132
CMax03's Avatar
Great!!! How did you like that .040" clearance with that caliper torque member? It's fine...I cruised like that for about 6 months B4 the rims came in.... Should've seen my former "00" with 02-03 front brakes assemblies and 16" Nissan rims. About to touch everywhere, spokes, inside surface of wheel...I'd like to seem someone put 15" wheels on a 02-03 without changing to 00-01 brakes. It's impossible!!!!
Old Mar 9, 2009 | 02:28 PM
  #133
spaceghost85's Avatar
after seeing pics of this i can't wait to do it to my 2k3 se
Old Aug 16, 2011 | 08:47 AM
  #134
gotahmax02's Avatar
Completed 6th gen front brake upgrade on 5.5 gen
Thanks to the info provided by LA02Max, I completed by 6th Gen BBK front brake upgrade this weekend on my 02 max
Bought 2 brand new Posi Quiet '05 "loaded" calipers from Tire Rack. Painted black since I didn't like the zinc coated finish. Bought 2 Centric '05 rotors from Tire Rack - Brembo blanks for 6th gen hard to find. Centrics come pre-painted black on the hub and vented areas. Even though calipers were loaded, during shipping several of the pads came out during shipping so when I installed I had to remove the caliper from the braket (tourqe member). Installation was simple with the exception that one of the TM bolts was very difficult to remove. Had to buy a breaker bar with a 19mm bolt to remove. Other than that, took about 5 hours to complete
Old Aug 17, 2011 | 04:24 PM
  #135
Bugeyes's Avatar
Im doing this next week, Rotor $30 each, Pads $20 set, Calipers $45 each... Same price for 5.5th gen set up so i mind as well step up to a 6th gen set up.
Old Mar 22, 2014 | 05:26 AM
  #136
frank5079's Avatar
My question is this... does this mod of upgrading to the 6th gen caliper and rotor significantly improve braking performance??
Old Mar 22, 2014 | 08:38 AM
  #137
ateick's Avatar
Search and I think you'll find the consensus is yes. There is another recent thread on the topic being discussed as well.
Matt93SE
May 24, 2019 02:58 PM
rbuswell
Nov 17, 2016 04:54 AM
Finkle
Sep 27, 2015 09:53 PM
FlaMark
25
Aug 28, 2015 10:15 AM
Lowered_a33
Aug 24, 2015 04:35 AM
