throttle body question
Old Feb 9, 2005 | 05:38 PM
PTP's Avatar
PTP
I cant find a write up here on how to clean the throttle body for a 2000 max after searching high and low. I did find a writeup on http://www.motorvate.ca/mvp.php/517 - the motorvate.ca site, but thats for a 97/98 and the 2000 looks different enough under the hood to confuse me.
So anyone have a good write-up on how to clean the throttle body for a 2000 max?
THanks
Old Feb 9, 2005 | 06:18 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
it is the identical process as the 4th write up you found. the only thing different is the intake resonator which is just a different size.
Old Feb 9, 2005 | 07:45 PM
PTP's Avatar
PTP
Does anyone know if I have to remove the air filter/oil separator / MAF as he recommends or can I just take off the accordian/worm hose to the throttle body and get the job done. Will I have enough clearance if I only remove this accordian/worm hose?
THanks
Old Feb 9, 2005 | 10:28 PM
frankd121's Avatar
You can probably just remove the accordian/worm hose and get into there if you have an aftermarket filter. But it'd probably be easier if you just removed the MAF/airfilter and oil separator.
Old Feb 10, 2005 | 02:14 AM
SoonerFan's Avatar
Cletus
http://www.cardomain.com/memberpage/335422/8
bryants95max
Oct 2, 2015 12:52 PM
97_GXE
Sep 15, 2015 06:47 AM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
Johnny9595
Sep 3, 2015 05:18 AM
