trouble programming a remote for the alarm
Old Feb 9, 2005 | 06:23 PM
bocian's Avatar
i lost my remote for the alarm and i got a new one... here the thin, i know how to program it (get in lock the door, put the keyu in the ignition at least 6 times, turn it to the acc position and press a button on the remote) i do that but nothing happens... my friend did it exactly the samew ay in his max and it worked. what gives? one thing is that when im taking the key in and out of the ignition, after the sixth time, the hazards blink twice but still the remote does not work...
thanks in advance, any and all help is appreciated...
Old Feb 9, 2005 | 10:19 PM
bigsherv's Avatar
you have to unlock the door with the switch after you press the button. Let me post the directions I used earlier today.
IMPORTANT: Before entering programming mode, have in possession all of the transmitters you will be using on the vehicle. Once you program the transmitter, all previous codes will be erased from the memory. The other transmitters will not be functional until you program the transmitters again.
1. Close and lock all doors with the driver’s side power lock/unlock switch.
2. Insert key into ignition and remove it from the ignition key cylinder at least six times within 10 seconds. Your Hazard Lamps will flash if you have performed this step successfully. NOTE: Withdraw key completely from ignition cylinder each time. If this procedure is performed too fast, system will not enter programming mode.
3. Insert key into the ignition cylinder and turn to the ACC position.
4. Within 5 seconds, push ANY button on the remote transmitter. Your Hazard Lamps should flash. NOTE: Do not press the button more than one time in the above step. If the button is pressed more than one time, the programming procedure will not be successful.
5. If there are any remaining transmitters (including the old ones), unlock then lock all doors using the driver’s side power lock/unlock switch and within 5 seconds, push ANY button on the next remote. Your Hazard Lamps should flash. Repeat this step for each transmitter (including any existing transmitters).
6. Turn the key to the OFF position, remove keys from the ignition, unlock doors using the driver’s side power lock/unlock switch and open the driver side door.
Old Feb 10, 2005 | 02:03 AM
bocian's Avatar
i greatly appreciate the help, thats what ive been doing but it doesnt seem to be working, ill try again tomorrow, following those exact steps. thanks again...
Old Feb 10, 2005 | 01:01 PM
bocian's Avatar
i did exactly as u said, but i got to the part where my car flashed the hazards, i then turned the key to the ACC position and pressed a button on the remote, but no reaction... any ideas? i tried with a friends remote and the same thing, no response from the remote.
Old Feb 10, 2005 | 01:33 PM
bigsherv's Avatar
after you push the botton on the remote try unlocking the door using the switch. Use both remotes becuase doing this erases the programming previously installed.
Old Feb 10, 2005 | 02:58 PM
bocian's Avatar
hey thanks again, i changed the remotes, turns out the two i used, neither one was the right one. neither had the right frequency, who would have though... lesson learned, never knew they had different frequencies, there are at least three that u know of now,
thanks for the input...
Old Feb 10, 2005 | 04:28 PM
steaLthyMax's Avatar
so theres 3 different remotes for the Maxima? each with a different frequency? What was the number on the back of the remote you tried to use?
Old Feb 10, 2005 | 07:00 PM
bigsherv's Avatar
Yeah when I got mine from ebay (for $9.62 cents each, wow) I made sure the numbers on the back matched.
Old Feb 11, 2005 | 02:46 PM
bocian's Avatar
i really didnt take a good look at the other remote's number, well not enough to remember it, but the one i hace has a couple different numbers on the back the the one that i remember was different was the FCC number, now i dont know if that is different on every remote or the other numbers but anyway, all three were different and only one worked... FCC # ID:NHVWBU43 thats the number that was different, i didnt really look at the other ones, which are
CANADA::17881021333
P/N:282682Y/NISSAN
what is what i dont really know but thats whats written on the back of the one that works...
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
zmcneely13
Sep 26, 2015 02:26 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
flu2000
Sep 14, 2015 12:34 PM
intimidator
Sep 5, 2015 07:23 PM
