Replacement of O2 Sensor P0158 CODE
Old Feb 10, 2005 | 08:06 AM
dmnsmith2's Avatar
Took my car to the dealer for the CEL coming on. They are telling me the O2 sensor is bad and needs replacing for $300. Is this something that would be easy to fix? Any tips would be appreciated. P0158 is the code. I have 54K on my 01 SE. Thanks...
Old Feb 10, 2005 | 08:11 AM
Sammzway's Avatar
Find out what the code is from the CEL. Take that code, and do some research on the org first. After that, if it is the 02 sensor that you need. Call up people on oxygensensors.com and tell them the code, they'll tell you which 02 sensor you need. It's about 99 bux there or less depending on which 02 sensor you need. They'll also give you a diagram of where the 02 sensor belongs. Or you can check nycmaximas.org in 5th gen area for a sticky of the diagram of all the sensors. Take it to the local shop, have them replace it for $40, and finito. Goodluck.
Old Feb 10, 2005 | 08:14 AM
Sammzway's Avatar
P0132 - Heated Oxygen Sensor 1 Circuit High Voltage (Bank 1)
P0133 - Heated Oxygen Sensor 1 Circuit Slow Response (Bank 1)
P0134 - Heated Oxygen Sensor 1 Circuit No Activity Detected (Bank 1)
P0138 - Heated Oxygen Sensor 2 Circuit High Voltage (Bank 1)
P0139 - Heated Oxygen Sensor 2 Circuit Slow Response (Bank 1)
P0152 - Heated Oxygen Sensor 1 Circuit High Voltage (Bank 2)
P0153 - Heated Oxygen Sensor 1 Circuit Slow Response (Bank 2)
P0154 - Heated Oxygen Sensor 1 Circuit No Activity Detected (Bank 2)
P0158 - Heated Oxygen Sensor 2 Circuit High Voltage (Bank 2)
P0159 - Heated Oxygen Sensor 2 Circuit Slow Response (Bank 2)
Old Feb 10, 2005 | 08:24 AM
dmnsmith2's Avatar
Is this covered past the 36K mile warranty?
Old Feb 10, 2005 | 08:33 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Follow this and you will find your answer:
http://forums.maxima.org/showthread.php?t=374481
mrc00l88
Jan 25, 2024 01:14 PM
AnsonJ
Jun 2, 2017 01:35 PM
Maxboy23
Aug 21, 2015 11:02 AM
maxinout93
Aug 20, 2015 02:17 AM
doobadoo
Aug 15, 2015 06:43 PM
