How do you open driver door
Old Feb 10, 2005 | 08:30 AM
bigsherv's Avatar
Guys, Since the dealer wants 80 bucks it is up to me to find that dang rattle. Can someone point me in the direction of how to open up the door?
Am I able to drive with it unassembled so I canl siten for the rattle? What I mean is will it still lock and stay shut with the panels taken out.
What do you all use to stop the rattle?
Old Feb 10, 2005 | 08:42 AM
brettb's Avatar
O'rly
You should be able to close the door fine without the panel and you can lock with your remote.
Old Feb 10, 2005 | 08:52 AM
bigsherv's Avatar
what about the how to on where all the screws are. WHat not to take apart, etc.
Brettb thanks for the reply.
Old Feb 10, 2005 | 09:14 AM
ihavea5spd's Avatar
Removal and Installation
NFBT0014
Front door finisher
1. Remove inside handle escutcheon.
2. Remove screw securing pull handle, and then remove pull handle.
3. Remove power window switch finisher, then disconnect the connectors.
4. Remove mask securing front door finisher.
5. Remove screw securing front door finisher.
6. Remove clips securing front door finisher.
7. Lift out front door finisher. Disconnect harness connectors.
Rear door finisher
8. Remove inside handle escutcheon.
9. Remove screw securing pull handle, and then remove pull handle.
10. Remove power window switch finisher, then disconnect the connector.
11. Remove clips securing rear door finisher.
12. Lift out rear door finisher.
If you need pictures, or more info, let me know.
Mar 12, 2020 12:06 AM
boomerbrian
Oct 31, 2018 10:25 AM
The Wizard
24
Oct 1, 2015 08:47 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
