Long term advice needed!
Old Feb 13, 2005 | 06:16 AM
nicks79's Avatar
Hello guys.
Started the car last night, and thing was shaking like crazy, seemed like cylinder misfiring. I drove like that for about a mile, and SES started blinking. then as it got warmer, it started to work normally. I drove to Autozone, and pulled these two codes, even though the light was off.
P0302 - Cylinder 2 Misfired Detected
P1320 - Ignition Signal
Now, does ECU remember what cause last occurence of SES light?
I had them damn coils replaced once under warranty, but can't find receipt saying that. Maybe stealer didn't replace them all, just one that was not functioning correct.
Now, I would assume that bad coil causes bad MPG, is that correct, even when I am driving and it is not misfiring??
Thanks for all your help...
Old Feb 15, 2005 | 09:18 AM
nicks79's Avatar
Anyone got any asnwers? Thanks
Old Feb 15, 2005 | 09:56 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Likley to be the ignition coils. If one goes the rule of thumb is to do them all...however the stealership would have only done one, that is sure-fire bet. If you're still under warranty I would go and get those done...but chance are good that you are going to have to do them all at some point in time.
Old Aug 27, 2009 | 04:56 PM
joeltender's Avatar
Just do the #2 coil.
Myself and many others have just changed the misfiring coil, and haven't had to change any others for a long time, but the other code might indicate otherwise, especially on 3.0
If the 1320 isn't related, just do #2
Old Aug 27, 2009 | 05:10 PM
rroderiques77's Avatar
Demodded and Forgotten
Another prehistoric thread lifted from the dead again!!!
I'm sure the problem has been solved by now..
smplyamzng
Dec 13, 2015 01:19 PM
TonyJr
Aug 20, 2015 12:14 AM
carlosvq30
Aug 17, 2015 11:32 AM
Flores94
Aug 11, 2015 12:53 PM
maxima297
Aug 3, 2015 12:50 PM
