D2R Retrofit. Glare or no?
Old Feb 15, 2005 | 06:28 PM
NYPD-Arnold's Avatar
Z
So before I purchase a pair of D2R bulbs, will they create a large amount of glare in my housing? My plan was to also aim the lights down slightly, as well. I think Ammi did a D2R retrofit, though I could be mistaken.
Any help would be great.
Old Feb 15, 2005 | 07:39 PM
ChromeSE5's Avatar
check HID forums, but if i remember correctly, our housings aren't really made for HIDs. If Ammi did do the retrofit, you might want to ask him to take a picture of the beam pattern against a wall. Im pretty sure though that there will be at least some glare.
Old Feb 15, 2005 | 07:45 PM
young1976's Avatar
You want to retrofit a D2R bulb into the 2k/2k1 housing? Why not just buy a H4 kit where the base is correct so you won't have so much glare? But if you Have the OEM HIDs already, then you might mean a D2S conversion... where you cut a notch into the D2S bulb base so it'll fit in the D2R recepticle.
Old Feb 15, 2005 | 07:49 PM
1FSTMAX's Avatar
You will need a D2R or D2S to H4 adapter... Try www.casperselectronics.com If done correctly the H4 housing shouldn't have excessive glare.
Old Feb 15, 2005 | 07:50 PM
1FSTMAX's Avatar
https://www.casperselectronics.com/M...Category_Code=
Old Feb 15, 2005 | 09:50 PM
Z
You. Are. The man.
Thanks!
trsandrew
Apr 8, 2016 06:45 PM
03VQMAX
Dec 7, 2015 04:59 PM
trsandrew
Oct 25, 2015 02:47 PM
Albertt
Aug 30, 2001 12:31 AM
Dr Donkey1
Mar 31, 2001 02:59 PM
