OSCAI Tube
Old May 1, 2001 | 09:38 AM
PhatGuy
For people who have done OSCAI I'm looking for recommendations for the type of tubing used? I've heard 2.5" or 3". Shop Vac tubing or standard 3" rain drain tubing? How long should the tube be to tuck down by the splash guard or through the cut insert? Does the silencer need to come out? I've seen Punk Dorks link but just looking for some additional info?
Thanks!
Old May 1, 2001 | 10:26 AM
punkdork's Avatar
There are varying opinions. I chose 3" diameter for more airflow. 4" was too big for me and anything smaller seemed too restrictive. I used rain tubing as a test... I want to get a smoother tubing, perhaps PVC so as to have less disturbance in the air flow. I have mine simply dangle straight down but others have brought them below the splash guard to create a ram air effect. It's custom so just do what you see fit!
Old May 1, 2001 | 10:55 AM
UMD_MaxSE's Avatar
Got Bent?
I am using 2.5" shop-vac tubing. I have it run down to the splash guard and I cut a small rectangular slit in it. The tubing sticks out of this slit facing forward. I have it so that if I want, I can push the tubing back up into the splash guard and close up the slit.
Old May 1, 2001 | 10:58 AM
max34's Avatar
PVC?
Is it possible to glue the L-shaped plastic doo-hicky that goes in the resonater onto a pvc pipe?
It would make a scoop and get more direct air flow from front of car rather from straight down.
Paint the pvc black, and it could look stock...just thinking out loud.
Old May 1, 2001 | 11:06 AM
max34's Avatar
PVC?
Old May 1, 2001 | 11:21 AM
punkdork's Avatar
Re: PVC?
Quite possible I'm sure, although you can buy a similar joint for normal PVC and then you should have no issues with it fitting.
Old May 1, 2001 | 12:50 PM
edadams's Avatar
I use 3" Flexible air duct hose available at any parts store, And cut a circular hole in the splash guard and zip tied a piece of rabbit wire to the splash guard I did paint the wire black. I tied the hose to the opening in the splash guard. And the hose hole is located on the front of the angled down section of the splash guard so it will force more air into the tube.
Old May 1, 2001 | 12:57 PM
max34's Avatar
Pics
Do you have any pictures of the tube going into th esplash guard?
I'm a little nervous at doing this without destructions...I mean directions.
Old May 1, 2001 | 01:15 PM
2001SE's Avatar
Do you think water and dust could get through when you put it down like an L shape.
Old May 1, 2001 | 01:22 PM
max34's Avatar
I imagine they would get in either way.
Old May 1, 2001 | 02:58 PM
PhatGuy
With the OSCAI i see the sensors are removed but it says nothing about reconnecting them. Do they need to be reconnected? I assume the would but what do i know?? :-(
Old May 1, 2001 | 03:15 PM
punkdork's Avatar
Yeah you reconnect them. The only reason you disconnect is to give you slack with the scoop.
Gingerheadman
Oct 1, 2015 05:11 PM
Sep 27, 2015 08:37 AM
DBear
Sep 14, 2015 08:33 PM
Slamrod
Sep 3, 2015 07:38 PM
Samedi
Aug 13, 2015 04:05 PM
