DDE Problem - HELP
Old Feb 19, 2005 | 08:34 PM
CRBWS6's Avatar
DDE Problem - HELP
One of my DDE light rings is not working. Has anyone experienced premature failure of their rings?
My initial problems were that the rings were intermittantly dim. I traced that problem to bad power ballasts which were replaced for free. Immediately upon installation of the new ballasts 3 of the rings work fine but one of the rings is not working at all. I have checked and re-checked all connections and have even switched the ballasts around to confirm the problem is with the ring. I just cannot imagine ring failing so quickly, it was probably only actually on for about 30 minutes.
Thanks...
Old Feb 19, 2005 | 10:22 PM
MaximaPolak's Avatar
Thanks...
Maybe you cracked the ring somewhere or the connection between the ballast and the ring is not good.
Mine work fine
Old Feb 19, 2005 | 11:27 PM
crispykid717's Avatar
Bigger than Jesus
Thanks...
This never happened to me but it's probably just a defective ring. You should contact Umintza directly.
Old Feb 20, 2005 | 12:05 AM
Triple8Sol's Avatar
I miss the .org!
Yes I have. Make sure the ring is at fault then contact Umnitza DIRECTLY. He will help you out.
Old Feb 20, 2005 | 07:37 AM
CRBWS6's Avatar
OK, thanks. Anyone else exerience problems with the rings; just trying to get a feel for how common this is.
I hadnt heard of anyone having probs with the actual rings...but it sounds like i am not the only one. It is weird that the things worked fine originally....but only during the very initial test. The thing that sux, is having to bake the headlights again!!!!!!! What a PITA.
Triple8Sol: Did you have any problems removing the ring from the housing, ie due the fact that it was 90-sec epoxied on (i assume)? I hope that it just kind of snaps off. Also, did unnitza take care of the ring at their expense??? So far, they took care of me on the ballasts, so happy there. I want to do the swap during a single baking, rather than bake, remove ring, send ring in, get new ring, bake again....hopefully they work with me.
Old Feb 20, 2005 | 09:37 AM
Call them, they will send you a new one or 4 like they did for me, and then you can send it back or throw it out. (see what they tell you.)
Old Feb 20, 2005 | 04:25 PM
Triple8Sol's Avatar
I miss the .org!
I had a burnt out ring when I 1st got the kit. Now one burnt out a couple months ago. I got the replacement shortly thereafter, but haven't had time to go in and put in the new one. Not sure how difficult that'll be, although I used clear silicone and not epoxy...
Old Feb 21, 2005 | 07:30 AM
I used crazyglue.
Old Feb 21, 2005 | 07:41 AM
CRBWS6's Avatar
Originally Posted by MaximaPolak
I used crazyglue.
I used the 90-sec epoxy by super-glue (which is probably very similar in hold to crazyglue) and i have noticed that one of the rings has already come unglued at the connection point at the bottom of the ring. So, i am hopeful that the top 2 connection points will pop off easily. But, if these rings have a tendency to fail all the time, i dont want to have to be using my oven more for cooking headlights than my wife does for actual food
Old Feb 21, 2005 | 01:12 PM
00MaxSE's Avatar
Pointy Elbows
One of my rings is really dim compared to the others. Sometimes when it warms up a bit, it turns bright again.
Old Feb 21, 2005 | 01:26 PM
CRBWS6's Avatar
That was my initial problem.....and replacement power ballasts fixed it. I just sent the orig ones back to umnitza returns (see their website) and they sent me new ones free. Man, time wise, these rings have been my most difficult mod
Old Feb 21, 2005 | 04:33 PM
TheBigDu's Avatar
Same problem here...
Hey guys,
You may remember I had the same problem about two months ago when I installed my DDEs. http://forums.maxima.org/showthread.php?t=367533 I've got pics there. Still haven't had a chance to take the lights back out and check out the problem. (I've been at school.) Hopefully I'll be able to check it out soon and that it's just a problem with the wiring. I REALLY don't want to think about having to remove the ring from the light if it is bad. I'm already pissed enough that I have to reopen the light to clean the marks from condensation, which I didn't think I originally had.
-Brian
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
