brake problem. Help please.
Old Feb 20, 2005 | 11:48 AM
Teser's Avatar
I changed rear brake pads and rotors yesterday. I couldn’t get one of the pistons back into caliper, so I disconnected the brake fluid line. After I put everything together, I took a test drive, and encountered a following problem.
When I push the brake pedal, at first I feel brakes starting to stop the car, but then the pedal travels down very easily without any effect on stopping the car. Only when the pedal is all the way down, then the brakes are stopping the car. BTW, I tested the hand brake, and it seems to work fine.
What’s the problem with my brakes? How can I fix it?
Help please.
Old Feb 20, 2005 | 12:24 PM
Y2k2maxse's Avatar
i had the same exact problem when i did my rear brakes. turns out that there was air in the lines. bleed the rear brake lines first, right wheel than left wheel. check your fluif level and try agIN
Old Feb 20, 2005 | 12:25 PM
Teser's Avatar
How do I do that? Any writeups available??
Old Feb 20, 2005 | 01:26 PM
geenowalker's Avatar
brake bleeding
Teaser,
If you still have not found out how to bleed the brakes, I can scan in the instructions from a manual and email them to you.
g
Old Feb 20, 2005 | 01:27 PM
have any of you guys replaced a caliper yet? Stealership wanted 660 to replace a siezed rear caliper that I bought from National Auto Parts. Planning on doing it myself, and was wondering how hard it is?
Old Feb 20, 2005 | 01:35 PM
Nissan SE-R's Avatar
Four bolts
A brake line
Bleeding the brakes
It will take you longer to jack up the car and remove the tire than it will to replace the caliper...
Old Feb 20, 2005 | 01:52 PM
Teser's Avatar
Originally Posted by geenowalker
Teaser,
g
thanks, I found some instructions online (http://www.stoptech.com/whitepapers/...rakesright.htm, http://www.stoptech.com/whitepapers/...rakesright.htm)
though I decided that I won't do this procedure by myself, and will take the car to my mechanics. I also need to replace dust seals in rear pistons (they are in very bad condition at 70k), so I ask them to do that and to change brake fluid.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
