New AM600 MAFS,still having hesitation after 4k HELP!
Old Feb 23, 2005 | 07:06 AM
Daily Driver2k2's Avatar
Guys i am outta ideas to finding out what is wrong with my Max, i need your help ! Last thursday went to work, car drove fine, strong, and robust, on the way home noticed car had a hard time getting over 4k rpms, SES light comes on.Went to autozone and had them read the codes,5 codes were present,1 was the MAFS , one was major exhaust leak, possibly the gas cap(had that happen before),the other 3 were 2 high voltage response and 1 low voltage response. Brought a AM600 MAFS, put that on , slightly better but car still has a hard time getting over 4500 rpms now. I then unplugged the car battery and let the ecu reset itself for exactly 24 hours. Hooked the battery back up , started car , SES light is off , took the car out for a test drive ,car seems a little bit repsonsive until WOT and the car just lags , once again right around 4500 rpms.
I changed the spark plugs with OEM replacements(NGK platinums) at 55k miles,cone filter is clean,religious oil changes,tranny oil flush and refil at 60k, car currently has 94k miles on it.
Also in nuetral the car would rev strong all the way to redline which puzzels me.
What do you guys think it could be?
Old Feb 23, 2005 | 07:49 AM
Anybody.....i am sure somebody has experienced this. your help is very much appreciated. I look through the stickies and i can't find a thing.
Old Feb 23, 2005 | 04:09 PM
EastSideMaxima's Avatar
A swift Bimmer driver
I heard that you have to reprogram the ECM after u replace the MAF... thats probably why its still acting up.
Old Feb 24, 2005 | 05:33 AM
03blk6mt's Avatar
After you get the AM600 MAF you do need to get your ECU reprogrammed. I just had this done under warranty by the dealer and although my hesitation issues are gone the car is a little sluggish. Not as bad as you're describing, though.
While you're getting your ECU reprogrammed, ask them to advance the timing +2 or 3 points.
Old Feb 24, 2005 | 06:53 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
Have the timing adjusted to +17^ BTDC while you're getting all that jazz done...
And yes, you must do an ECU reflash when you get a new MAF...
Old Feb 24, 2005 | 07:20 AM
GBAUER's Avatar
take it to an autozone and get 'er done fur free! Or, you can unplug the battery overnight. Your choice.
Old Feb 24, 2005 | 07:21 AM
E55AMG2's Avatar
Wat
Daily Driver: Come to the meet here:
http://forums.maxima.org/showthread.php?t=382071
and I can check your car out personally. I have a couple questions for you as well; do you still have the stock exhaust system, and how many miles are on the car.
Old Feb 24, 2005 | 09:26 AM
Kevin's Avatar
get it checked for free? or updated for free?
how much does an ECU update cost from nissan?
Old Feb 24, 2005 | 09:38 AM
E55AMG2's Avatar
Wat
The ECU update is a TSB...NTB03-023
OT n00bs FTMFCSL
You can't get the Consult II update for a new MAF at Autozone, or any other parts store for that matter. You do not need to reset the ECU...you need to input NEW DATA here folks...
Old Feb 24, 2005 | 09:41 AM
lex3015's Avatar
i replaced my MAF sensor 2 days ago. i did the switch, unplugged my battery....watched a movie, came back and reconnected it and my ses light was gone and my car is back to normal.
Old Feb 24, 2005 | 09:44 AM
OT n00bs FTMFCSL
He drives a 5.5th Gen, and you drive a 5th Gen. Little different procedures between his car and yours...so don't post unless you actually know what you are talking about, please.
Old Feb 24, 2005 | 10:22 AM
GBAUER's Avatar
sorry 'bout that. Thought they could.
Old May 10, 2005 | 03:31 PM
steven88's Avatar
Need A Light?
daily driver2k2....did u ever get your problem resolved? i am experiencing the same problems as you...i have a 2k2 but replaced it with a 22680-2y001 MAF...instead of the 22680 AM600 (costs $400)....i slapped her on and gained some power back....but noticed my car goes nowhere after 4k.....and I also do have a VERY hard time starting up my car....
i'm planning to go to a stealership to get this settled....via consult II.....just wondering if u did it...
Old May 10, 2005 | 03:37 PM
E55AMG2's Avatar
Wat
Do you have stock manifolds?
Old May 10, 2005 | 10:14 PM
steven88's Avatar
Need A Light?
yup....stock exhaust+intake manifolds.....why do u ask btw? do u suggest that my exhaust manifold precats are clogged and causing me to experience this? blackbirdVQ told me something about this awhile back....but i dunno
Old May 10, 2005 | 10:51 PM
E55AMG2's Avatar
Wat
The precats are indeed melted...probably along with your stocker. This is why you have no response past 4k.
Old May 10, 2005 | 11:15 PM
steven88's Avatar
Need A Light?
you think so e55? you still think i should go to the dealers and have them reflash my ECU? I did get a new maf for my 2k2....a 22680-2y001 though...it's off a 2k-2k1...all i did was transfer my IAT...
I still get a nasty start-up and my low end is still not up to par before the limp mode...it did get a little better than BEFORE i installed the 22680 2y001...i just want everything to go back to NORMAL...and i heard blackbird tellin me its necessary to do the reflash in order for everything to go back to normal...
is there anyway to determine if my precats are clogged without actually removing the whole exhaust system? i heard header installs are PITA and I don't wanna tackle it until i'm for sure my MAF or precats are dead....
sorry for the newbie-ish questions....i'm just in need of help....this limp mode is ghey :0
Old May 11, 2005 | 06:43 AM
Puppetmaster's Avatar
that would suck...
I actually thought ya had headers, Steve...
Old May 11, 2005 | 07:05 AM
kcowden's Avatar
Sounds like this should solve your problem. Had the same problem and this fixed it.
Old May 11, 2005 | 09:06 AM
E55AMG2's Avatar
Wat
You should have the flash done and MAF changed. If thats the problem, no sweat and maybe $100 to fix (if they charge you). If that doesnt fix it, go ahead and get yourself some headers and have them installed, those should clear up the problem (and give you a couple hp to boot )
Old May 11, 2005 | 09:09 AM
steven88's Avatar
Need A Light?
Originally Posted by Puppetmaster
that would suck...
i do...but it's not on the car yet....i'm thinking of updating the MAF + advancing the timing at a stealership....before i slap on the headers....if the problem still exists even with the MAF update....then it must be my precats...time for some cattman headers
Old May 11, 2005 | 11:39 AM
E55AMG2's Avatar
Wat
Timing advance has not shown any conclusive gain on the 3.5...save your $$$ and just have the MAF and reflash done. Then, go ahead and install the headers.
Old May 11, 2005 | 12:42 PM
Shogunsc4's Avatar
that's weird...I blew my stock 22680-AM600 on my 2k3 and replaced it with a new (same part#) 22680-AM600 without a reflash and my car drives strong. So, replacing the same sensor needs a reflash?
Old May 11, 2005 | 04:40 PM
E55AMG2's Avatar
Wat
On the 2002's they got a bad fuel map/ignition map (lack of power and hesitation) as well as the 22680-2y001 MAF sensor. Early 2003s didnt have the software, but did have the MAF. Later production 2003s came with both.
Old May 11, 2005 | 07:28 PM
steven88's Avatar
Need A Light?
e55 - but since they are going to have the consult II hooked up anyway....might as well do my timing right? heard it literally only takes 5 seconds....oh btw i found a stealership who can do my MAF update....they said 42 bucks out the door...i was like SWEET! lets do this!
Old May 12, 2005 | 09:26 AM
E55AMG2's Avatar
Wat
The MAF and software flash takes about 1 hour (the software takes about 1 hour to flash at 9600kbps, which is the speed of an OBDII port) and you cant do anything else while its flashing. If you really want the timing done....go for it, but there really is no proven benefit to it. $42 out the door is a steal....go for it.
Old May 12, 2005 | 09:32 AM
steven88's Avatar
Need A Light?
e55 - gotcha....i can now see where yer coming from....anyway i'll keep you and the other members posted...just in case ya'll 2k2-2k3 owners have some stupid problem like this...
Old May 12, 2005 | 10:13 AM
E55AMG2's Avatar
Wat
I did....2 years ago.
Old May 12, 2005 | 03:58 PM
steven88's Avatar
Need A Light?
UPDATE - okay back from the stealership....I ended up talking to another service rep and told him I need new software for my ECU becuz of my new MAF....he says "that will be $85"...and i'm like "wtf? I talked to Fred yesterday and he quoted me only $42"....so he walks over and brings Fred....and he informs me that the MAF indeed is $85 to fix becuz its an hour labor....he just made a mistake on the phone yesterday .....
anyway he felt bad for me and said he'll do everything for $70...i said cool u better fix it....so then after an hr later...i get my car keys back and fire her up...still a rough start...but when i took it on the streets...a noticeable power gain....it seems to pick up fairly well now....but i do experience a big loss in the mid-range and high-end....so i'm going to conclude its my exhaust manifolds.....but it sux though...i gotta drive like this for awhile until me and my friends can go install it
E55 thanks for all the help...appreciate it
Old May 12, 2005 | 04:01 PM
E55AMG2's Avatar
Wat
NP man.....my car is the reason they wrote that TSB
Old May 12, 2005 | 04:02 PM
steven88's Avatar
Need A Light?
lol r u serious? theres a TSB for headers? or are u talking about the MAF issue?
Old May 12, 2005 | 04:19 PM
Shogunsc4's Avatar
e55...do u know on top of your head if my ride be considered the early or the late model if it is made in july of 2002?
steven88...just curious, what is the manufacture date for your ride and yes you ride is sweet yo.
Old May 12, 2005 | 04:46 PM
steven88's Avatar
Need A Light?
thanks shogun...my production date is 10/01....i believe for 2k2's they had 3 dates....9/01 10/01 and 12/01....not totally sure though
i think 7/02 an early one....not totally sure though....but i know for sure the 2k4 maximas were seen in lots mid 2003 as an 2004 model....so i bet the 03 maximas had to be produced real early and sold early
Old May 12, 2005 | 04:55 PM
Shogunsc4's Avatar
cool cool. I'm still deciding if I should get a reflash and get the timing advance. My ride pulls smooth and strong after 4k...sometimes I feel a slight torque steer on the highway if I slam it when it is near redline (not sure if torque steer is the right word lol)
Old May 12, 2005 | 05:03 PM
steven88's Avatar
Need A Light?
thats cool...if u do decide...go to superior nissan....it's right next to yer house too....ask for Fred and Aldolfo (his personal tech) at service dept....they flashed everything for me for 70 bucks...but ionno if they will do it for u at 70....Fred just felt sorry for me cuz he gave me the wrong price over the phone....but just ask anyway....$85 is still a reasonable price though...i mean it does take awhile to upload the info...oh yeah when u ask to change the base ignition timing...make sure u tell that to Aldolfo (not Fred) cuz Aldolfo knows all that stuff while Fred will have no clue and might just say no for liability issues....
Old May 12, 2005 | 05:06 PM
Shogunsc4's Avatar
i went and talked to 2 service managers...Jordan and William last year and they both tripped out on me. So just ask for Aldofo...cool i'll do that
Old May 17, 2005 | 11:29 AM
Shogunsc4's Avatar
went to the dealer to get the ecm update. Talked to Fred and Aldolfo...good service. Plugged my car up with a consult II and advanced my timing to 17 btdc and did the idle air learning. The tech Aldofo told me that I don't need the ecm update as he explained to me that steven88's car is different. He showed me on the consult II how my MAF voltage is at ~1.2V and it is running normal along with everything else and if I get the reflash the voltage will differentiate with the MAF and will run like crap. He thinks my car has been updated already...so I went by what he said. As for the timing advance...not much different maybe a tad bit more pull down low.
Old May 17, 2005 | 12:03 PM
steven88's Avatar
Need A Light?
great to hear shogun....I knew Fred&Aldolfo were no BS service...they really know what is going on.....
anyway they remember my car? hha thats weird....well if you told them a guy named steven...then they definitely won't remember...cuz my real name isn't steven...lol...well glad to hear they advanced your timing without any questions asked
as far as updating the ecu/maf....just like e55amg2 said...if u have a late model 2k3 i don't think u have to worry too much...only the old 2k2s had this problem and require updating....and i have an old 2k2...so yeah....i can't really determine how well my timing advanced is....cuz my car is still running like ****....but i did notice a different change in sound....how about u shogun?
Old May 17, 2005 | 01:05 PM
MIKE2K2's Avatar
Custom User Title
Originally Posted by kasonw
hey,
i got my max more than half a year now and have been reading through these threads and seeing few of the same discussions over and over, i don't mind it, newayz... your hesitation/power loss from 4500 and up could also be because your VIAS is not working at all... go to the HOWTO sticky thread and look for the VIAS fix... our 5th gen max's got a variable intake manifold which opens a second pathway for air to go to the engine. Fix that and the higher RPMs should feel stronger. I did the fix on my car because i was feeling my car as it pass 5000rpm to feel dead dead, as if it was doing a reverse VTEC feeling (i use to own an '92 integra GSR ). After i fix it it felt better, no more power loss feeling. Then recently i felt the car taking real long going from 3000rpm to 4500rpm. This was the MAF, so i went to pinnacle nissan and ordered the new MAF for $78 (great deal), got it and BOOM, the car feels much much stronger throughout the entire rpms, now when i floor it WOT, the car races up the rpm and as it hit pass 5000rpm and the VIAS activates the growl is amazing. Everything is stock in the car for now. next fix is whatever little dents and paint scratch i got on it.. gonna be a $600 job. then its fresh ignition coils and plugs. Hope my experience helps. laters
Kason
3252646573457
TallTom
57
Oct 14, 2025 05:16 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
JoshG
51
Sep 21, 2015 10:41 PM
jchronis2552
Sep 21, 2015 05:52 AM
ballerchris510
Sep 10, 2015 09:35 PM
