02 Maixma High Idle HELP!!
Old Feb 23, 2005 | 08:59 PM
wow8877's Avatar
i was told i needed to get my throttle body cleaned out by nissan because my car wasnt performing very well, so i had it done a week later my service light came on, the computer said i have a "High Idle" so i was told i had to change my throttle body which i did but i still got the same problem, my mechanic said my MAF sensor is fine. dont know what to do any suggestions.
Old Feb 23, 2005 | 09:06 PM
Nismo3112's Avatar
Custom User Title
so let me get this straight..... you replaced your throttle body because you had a high idle?
Old Feb 23, 2005 | 09:14 PM
tothemax319's Avatar
Did the dealer tell you it threw a high idle code? Sounds like your throwing the code known as "The Stealership is robbing you blind".
Old Feb 23, 2005 | 09:29 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
HIgh idle code is caused by a bad throttle body, they cost like 1100 bux list price new. 02-up have the "wonderfull" drive by wire that CAN cause alot of problems in the future with drivability, Audi comes to mind when their throttles go bad after 3-4 years of usage. I would make the dealer eat the throttle body if they cleaned the throttle with a tooth brush and bent the butterfly while trying to keep it open- which is probably what happened. I think Maxima Polak did the same thing one time and ended up getting a new throttle body for his car under warranty.
Old Feb 23, 2005 | 11:36 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
What do you mean "i had to change my throttle body which i did"? Did you replace it yourself?
Even if the dealer did the repair, try the IAVL procedure in the sticky above. It has helped a few that had this happen after a TB fluckup.
I've read WAAAAAY too many TB cleaning horror stories lately, especially you 2K2+ drive-by-wire guys. That servo motor must be a touchy SOB. One guy even had to replace his ECU after a botched TB cleaning.
Leave well enough alone, I say.
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
