car is stalling NONSTOP!!
Old Feb 24, 2005 | 02:25 PM
OOmaxSE's Avatar
say i'm going about 40mph and there is a stop light ahead so i anticipate it and just shift to N and the RPM drops and then STALLS. now another scenerio, i'm in 5th gear and going to a stop sign and i ride the gear down to 1grand and hold the clutch down completely... i still stall!!! i need helppp. i just got a clutch job and my catback is completely crushed and there's a huge bend in it, like it's halfway pancaked, could this be it?
Old Feb 24, 2005 | 02:35 PM
KCMC582's Avatar
im sure the crushed catback pipes cant be helping the situation, maybe causing a problem with the backpressure. but i dont think i could cause you to stall that frequently.
Old Feb 24, 2005 | 02:52 PM
2kprlmax's Avatar
it's probably the MAF
Old Feb 24, 2005 | 03:34 PM
OOmaxSE's Avatar
could it be like spark plugs? my SES light is on for my o2 sensor after the precat
max929's Avatar
Stalling
I'm having the same problem. Has anyone replaced their MAF while having this problem?, Did it FIX the problem???????????????
Old Feb 24, 2005 | 03:49 PM
nicks79's Avatar
Almost positive its MAF. Had the same problem like you described. I didn't know what it was then, so I took it to the dealer to diagnose it. Turned out to be MAF.
Old Feb 24, 2005 | 03:57 PM
OOmaxSE's Avatar
oh oh, how much do those MAF's go for? and SES light doesn't light up for MAF's?
Old Feb 24, 2005 | 04:35 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
60 bux for MAF just for the element piece with no tube.
Old Feb 24, 2005 | 04:38 PM
Progress's Avatar
It's business time.
No SES with MAF failure. At least I didn't have one.
Old Feb 24, 2005 | 04:46 PM
Ammi's Avatar
350 Detroit Muscle
Someone had similar problem and I told him to clean his TB. Problem solved.
Old Feb 24, 2005 | 06:12 PM
ZIPPIN's Avatar
Mauja He Mauja
where?????????????????????
Old Feb 24, 2005 | 06:25 PM
Stardust's Avatar
F---ing Kangaroos
Cleaning my TB fixed my stalling problem.
Old Feb 24, 2005 | 07:09 PM
JDM_Maxima's Avatar
definately check your MAF, was a guy in th 4th gen furom that what battling with the same issue for months and spent quite abit of money trying to find out the problem. he went to a dealer and got a computer diagnostic and it came up, he changed that MAF sensor and all his problems were fixed. you might want to check to see if you have any vaccum leaks
Old Feb 24, 2005 | 08:19 PM
OOmaxSE's Avatar
alright, so i'll (1)clean out my MAF sensor, (2)clean the TB... eventhough i don't know how, if (2) doesn't work, i'll buy a new MAF
Old Feb 24, 2005 | 08:55 PM
OOmaxSE's Avatar
i searched and searched and i can't find how to clean the TB... anyone know the link?
Old Feb 24, 2005 | 09:22 PM
Max20SE00's Avatar
i dont know the link but take off your stock air box... Pretty easy just look for the bolts that hold it down. Once the bos is removed you will see the throttle body with a metal ring that you can push up. I just sprayed some stuff in there and wiped it out with a rag.
Old Feb 24, 2005 | 09:36 PM
OOmaxSE's Avatar
oooh, so you gotta take off the intake pipe as well? i have factory airbox... so basically you clean the lever that flaps? and what's inside that part? and don't clean the intake pipe?
Old Feb 24, 2005 | 09:39 PM
Max20SE00's Avatar
yes take all the air box out and clean all where that thing flaps. It will take about 45 min. or so to take it all out and clean it and put everything back. But I only had 60K on my 2000 and the rag was black. Buy some throttle body cleaner at walmart or something and spray it in thdere and wipe it out.
Old Feb 24, 2005 | 09:56 PM
OOmaxSE's Avatar
yeah i have 58,xxxk on my car now. when did you replace your sparks? or are you still running stock plugs?
Old Feb 24, 2005 | 10:03 PM
Max20SE00's Avatar
I replaced the spark plugs the same time at 60k and noticed quite a difference, even though nissan says there good for 100k
Old Feb 24, 2005 | 10:43 PM
I said the MAF price, I didn't say that is what is wrong with the car thou Clean your TB first, unplug the battery over night and let the ECU relearn everything. I have bought 4 MAFs from the dealer at 56 bux each 2 years ago, prices have gone up slightly this January when Nissan raised their prices. 56 bux got me just the sensor element, with no tube. I got 2 spare ones just for my own car in case the one I have in there now decides to go out.
Old Feb 24, 2005 | 11:47 PM
OOmaxSE's Avatar
i have factory airbox, is that the tube you're referring to? or do you have to get a new tube each time you replace one MAF. can i start the car up after cleaning the TB or let it sit overnight with the battery unplugged, then start it up?
Old Feb 25, 2005 | 06:23 AM
2kprlmax's Avatar
Mine was under warranty so it was fixed for free. No the SES light didn't come on for my car
Old Feb 25, 2005 | 03:41 PM
OOmaxSE's Avatar
did the maf failure make your car sufficiently slower? my car is so slow right now! could this be my pinched/flat part in my exhaust b pipe?
Old Mar 1, 2005 | 03:51 PM
Eenis's Avatar
I have the same situation. Mine will stall for about a week or so, and then run fine. Did it 3 times in 15 mins. today. But doesn't the MAF make the car run sluggish though? At least on mine, I've seen no decrease in performance with the stalling issue.
Old Mar 1, 2005 | 04:02 PM
OOmaxSE's Avatar
MAF will make your car slower/accel slower while i think the TB will increase stalling. you stall with MAF failure too.
Old Mar 1, 2005 | 04:16 PM
max929's Avatar
No More Stallsssssss!!!!!!!!!!!!!!!!!
Fella's, Clean out your throttle Body!!! My 2k was stalling none stop!!!
So I did some research on this (KICK-***) forum and found instructions on how to clean out the TB. It takes about 1 hour and the hardest part is the buttom left screw on the MAF(If you are faceing the front of your sexy MAX). Cleaned it out with a can of Air intake/throttle body cleaner and PRESTO!!!!
MY 2K has never run so well and I have done every thing to get it to Stall. I have raced up to traffic lights, taken the car out of gear(I have a 5sp) and braked hard, NO PROBLEMS
Here are the links:http://www.motorvate.ca/mvp.php/517
http://www.motorvate.ca/mvp.php/518
Old Mar 1, 2005 | 07:58 PM
OOmaxSE's Avatar
nice i read it and it sounds very nice, i will do it this weekend. my only question is, did your car feel WEAK and accelerated slowly before you cleaned it? because my car feels UBER weak and slow.
Old Mar 1, 2005 | 08:07 PM
max929's Avatar
Ahh
Not really, it had power but it was not like it is now. You will deffinatly notice a difference in power after you clean it out. How many miles are on your MAX??? You will be shocked at the mount of S H I T in there.
Old Mar 1, 2005 | 08:26 PM
OOmaxSE's Avatar
mann, i only have 58,xxx miles, i think that's pretty low for a 2000. but i bought it used and the person before me had mods. so you cleaned your TB, did you disconnect your battery also? i heard you should do this for 1-3 hours after to reset the ECU. what was your whole procedure?
Old Mar 1, 2005 | 08:56 PM
max929's Avatar
Didn't reset the ECU, just pulled it apart, cleaned it, put it back together. Took about an hour!!!
Old Mar 2, 2005 | 04:14 AM
ZIPPIN's Avatar
Mauja He Mauja
you pulled apart the ECU???
Old Mar 2, 2005 | 06:08 AM
CCS2k1Max's Avatar
If it isn't the TB, just change the MAF. There's no cleaning of the sensor, all you'll do is f' it up.
4th Gen, but you get the idea.
Old Mar 2, 2005 | 10:57 AM
Y2k2maxse's Avatar
its probably your MAF mine was going i stalled a few times I replaced it and at the same time cleaned out the throttle body runs like new never stalls or even gets close to it
Old Mar 2, 2005 | 04:04 PM
OOmaxSE's Avatar
anyone know links where i can get a new MAF? last place i wanna go will be stealership, hey maybe NAPA?
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
