Please help identify this noise
Old Feb 25, 2005 | 01:23 PM
steelymatt's Avatar
Hi,
I recently started getting a noise that sounds like a rrr...rrr...rrr from the front end at around 45-50 mph. It happens when I'm just cruising, no brakes applied. I don't think it's my tires because I recently had them balanced and there's no shimmy in the steering wheel. Does anyone have any ideas what this could be?
Thanks.
Old Feb 25, 2005 | 01:40 PM
GBAUER's Avatar
Wheel bearings. Common problem in the 5th gens (not so for the 5.5 for some reason).
Old Feb 28, 2005 | 08:51 AM
steelymatt's Avatar
Any possibilities other than the wheel bearings?
Old Feb 28, 2005 | 08:56 AM
Galo's Avatar
Maxima Pilot
Sure there are 'possibilities'...some very remote possibilities are u have a diff going bad, a tire going bad, etc.....
The 98th percentile probability?? Bearings as posted above
Old Apr 9, 2005 | 11:29 AM
steelymatt's Avatar
If found the problem. It was a bad tire:
http://forums.maxima.org/showthread....=1#post3864534
Old Apr 10, 2005 | 03:11 PM
optimus1's Avatar
noises
Is it coming from only one side of the car?
My 2000 Max w/ 68 kmiles, the Belt tensioner pulley is vibrating and causing a noise (rrr) from engine speeds 1000 to 2200 rpms ... I think the Bearings in the Tensioner Pulley are about to freeze up. At idle, reach into the engine comparment and put some tension on the Idler Pulley Assembly, and listen for the noise ... (it sounds like a tranny pump getting weak).
Old Apr 11, 2005 | 01:18 AM
maxfive-O's Avatar
Check your tire air pressure, Low pressure will make noise. If not, Take off the tires and make sure you don't have a defected one. Happen to me in the past. Go cheapest fix first, Could be that simple.
Old Apr 11, 2005 | 03:32 AM
steelymatt's Avatar
Are you guys paying attention, I found the problem. See 2 posts up.
Old Apr 11, 2005 | 08:17 AM
brettb's Avatar
O'rly
I had this problem and it was the wheel bearing and hub.
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
