Hissing noise at the front of the car. Help..
Old Feb 25, 2005 | 06:30 PM
LithiuMax
Recently, I have noticed a hissing/rubbing/metallic sound that seems to be coming from the front passenger side of the car, probably from the wheel well. It starts at around 15mph, but when I brake, it stops. Also, when I tap the brake pedal fairly hard (without coming to a complete stop), the noise stops briefly but then returns.
Any ideas?
Old Feb 25, 2005 | 06:32 PM
ZIPPIN's Avatar
Mauja He Mauja
caliper not letting go! not disengaging!
Old Feb 25, 2005 | 06:40 PM
LithiuMax
OK.. how do I go about stopping that from happening?
Old Feb 25, 2005 | 07:00 PM
irish44j's Avatar
retired moderator
or...the metal dust shield behind the rotor is rubbin on the back of the caliper....a common problem
Old Feb 25, 2005 | 07:14 PM
LithiuMax
So how can I fix it?
Old Feb 26, 2005 | 12:00 PM
LithiuMax
Anyone?...
Old Feb 26, 2005 | 05:17 PM
ZIPPIN's Avatar
Mauja He Mauja
if it is the dust shield: it is a pretty soft metal shield. just bend it away from the rotor. if that does not fix it, then you may have to replace the caliper. but before you replace the calliper, have someone drive the car slow, and run next to it. make sure thats the problem. if it does not get fixed after bending the shield, try cleaning the caliper and re-greasing it, before replacing the caliper
Hondarydr
Dec 30, 2024 06:15 PM
Matt93SE
May 24, 2019 02:58 PM
boomerbrian
Nov 8, 2015 05:10 PM
maxinout93
Oct 27, 2015 01:29 PM
Starrider
Sep 17, 2015 07:26 AM
