got my MAF now what!!!
Old Feb 27, 2005 | 12:48 PM
petselh's Avatar
just some advice please
I know, I know everyone will say do a search and I have but wanted to know if I have everything covered.
If I only disconnect the negative will the car go back into reprogram??
Do I have to get the dealer to reprogram the ECU I read where some of you didn't after replacing the MAF and it was ok?
Main thing is also to clean the throttle body!!!
Anything else I leaving out??
Old Feb 27, 2005 | 12:53 PM
Kruppa's Avatar
if you have a 00-01 just disconnect battery for a few hours, but if you have a 02-03 there is a more complicated reset process that i'm sure somebody has a link to
Old Feb 27, 2005 | 12:54 PM
lex3015's Avatar
i replaced mine last week. all i did was swap the maf then just disconnected the negative for like 2-3 hours, came back and i was all set. ses light was gone and my car is running like a champ. hope that helps, good luck
LA02MAX's Avatar
the 5.5 gen ECU reset procedure is in the 5th gen how-to's
Old Feb 27, 2005 | 05:03 PM
ekg2's Avatar
The new MAF (part #22680-2Y001) need an ECU upgrade so if you had a factory MAF before you'll probably need the dealer to reprogram the ECU. Although some people claim disconnecting the battery worked, might as well try that first and see what happens. Let us know...
Old Feb 27, 2005 | 05:08 PM
Y2k2maxse's Avatar
not true its just plug and play my car ran real slow i just connected the new one and cleaned out the TB no batt. disconnect no ECU reprogram runs 6.8 in 0-60 now. fast as hell. Great response.
Old Feb 27, 2005 | 07:22 PM
OOmaxSE's Avatar
i gotta do this now, i feel like my car is so weak i step on it and it just sounds more airy, not faster. so basically just plug in the new MAF, disconnect negative terminal in batt for 2-3 hrs, and clean throttle body?
Old Mar 1, 2005 | 07:07 PM
Bruceman's Avatar
I have an 03, where would I find an aftermarket MAF for my car?
TallTom
57
Oct 14, 2025 05:16 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
ballerchris510
Sep 10, 2015 09:35 PM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
