Where is the best place to get OEM brake pads?
Mar 4, 2005 | 03:47 PM
I need them cheap, and I need them soon!
Anyone know? Also, how much is it to turn 1 OEM rotor, usually?
Mar 4, 2005 | 03:50 PM
call Dave Burnette.....
Mar 4, 2005 | 03:51 PM
Quote: call Dave Burnette.....
Damn.. I forgot all about that guy. Do you have his number off hand?
Mar 4, 2005 | 03:54 PM
you can search
Mar 4, 2005 | 03:55 PM
Mar 4, 2005 | 03:58 PM
Quote: you can search
10-4
Thanks maxilvr..
Mar 4, 2005 | 04:03 PM
I was going to ask you about your brakes being worn out on an 03 until I saw where you live.
Mar 4, 2005 | 04:18 PM
Quote: I was going to ask you about your brakes being worn out on an 03 until I saw where you live.
I'm right at 21,000 miles, and there's a strange sound coming from my right front wheel. Metal on metal scraping while I am NOT braking. As soon as I press the brake pedal, it goes away. My diagnosis is that there's no pad there any more..
Mar 4, 2005 | 04:37 PM
Have you taken the wheel off to verify?
Mar 4, 2005 | 04:54 PM
Quote: Have you taken the wheel off to verify?
No.. but I will later today or tommorow.
Mar 4, 2005 | 08:41 PM
That strange sound that you are hearing is probably the wear indicators rubbing on the rotor. Your rotors are probably OK if you change your brakes soon.
I hope this helps...
Gears
Mar 5, 2005 | 05:34 AM
Quote: That strange sound that you are hearing is probably the wear indicators rubbing on the rotor. Your rotors are probably OK if you change your brakes soon.
Gears
I would think that the noise he described would not go away when he applied the brakes if it was a tell tab (wear indicator). The only real way to tell is the remove the wheel and inspect it.
Mar 5, 2005 | 07:40 AM
Zero,
I respectfully disagree. I have had this same condition on many of my cars. The fact that the noise goes away when he hits the brakes is a dead give-away to me. I know it doesn't make sense, but that's what I have experienced.
I am assuming that the noise that Lithiumax is hearing is that high pitched scraping metal /"wear indicator" noise. But like Zero said the only way to find out is to take that wheel off!
Just sharing,
Gears
Mar 5, 2005 | 09:22 AM
I reckon we'll have to wait and see what Lithiumax finds out.
Mar 6, 2005 | 04:48 PM
By the way Zero Deuce... nice Max
Mar 6, 2005 | 05:03 PM
Quote: By the way Zero Deuce... nice Max
Thanks mate.
