grille tech grills
Old Mar 4, 2005 | 06:54 PM
The Kid's Avatar
grille tech grills
when installing the new grill does it mount the same way as the oem one. also how do u remove the bottom 2 oem grills not sure if they can come off but if they do i cant figure it out thanx.
Old Mar 5, 2005 | 10:35 AM
CRBWS6's Avatar
on 5.5 gens, the grill installs totally different - it conncets with cable zip ties only (provided with grille).
the lowers install over the stock black plastic "slats". also using cable zip ties.
Old Mar 5, 2005 | 11:41 AM
The Kid's Avatar
ok kool i took the main grill off so u cant see the oem one. it will still be able to stay stiff with the zip ties correct. i didnt know they connected with zip ties cause ive seen pictures and it didnt look like it did but o well lol thanx.
Old Mar 5, 2005 | 01:03 PM
XGaSpAcHo
i only have the bottom ones on and they've stayed on with the zip ties no problem. just make sure you pull them tight enough so they dont vibrate at high speeds.
REDinLV
Aug 15, 2024 12:30 AM
05RLS2
Nov 7, 2016 05:52 PM
Redfox
Sep 28, 2015 10:41 AM
REDinLV
Sep 28, 2015 12:31 AM
ricky7780
Sep 24, 2015 06:50 PM
