LSD vs. Locker
Old Mar 7, 2005 | 10:19 AM
RacertilTheEnd's Avatar
LSD vs. Locker
I found that there is a company who sells front lockers. I also found a company who makes a LSD system for the maxima. I would like to know what one is the best bet to go with. In other words, what is the most effective.
P.S.
Great to be back on the forum.
Old Mar 7, 2005 | 12:14 PM
03blk6mt's Avatar
P.S.
Depends on what you do with your car...if you drag race (on the track) where you do little turning then a locker should be your choice, if you drive your car on the street the LSD is what you want . The difference being when you turn a locker will cause the inside tire to chirp and catch because it's trying to spin at the same rate as the outside tire. Somelockers allow some slipping for turns such as Detroit but you get a loud annoying click. The Lsd allows your wheels to spin independently until it recognizes slip on one of the wheels. Which company are you talking about that makes an aftermarket LSD?
Old Mar 7, 2005 | 12:21 PM
mantaray motorsports.
http://www.mmrusa.com/phantom1.htmht...m/phantom1.htm
it is a LSD conversion kit
Old Mar 7, 2005 | 12:23 PM
SailRace's Avatar
Unless you're doing heavy drag racing, or offroading, a locker is pretty much useless. I've had them in my Jeeps before. Great for getting up and over things, but for everyday driving, they're very unfriendly (loud and clunky).
Old Mar 7, 2005 | 12:26 PM
Jeff92se's Avatar
I'm needing a caw
No one in their right mind would sell a "locker" for a fwd.
Old Mar 7, 2005 | 12:33 PM
The mantaray LSD conversion apparently acts like a locker under hard acceleration but in cornering and what not, it switches to LSD, a disc type if I am not mistaken.
Old Mar 7, 2005 | 12:35 PM
Jeff92se's Avatar
I'm needing a caw
disc types are also not lockers
Old Mar 7, 2005 | 12:49 PM
I was saying that the LSD acts like a disc type, I don't know a lot about LSD's but I do know that a disc type is not a locker. What I was saying is that the mantaray LSD acts as a locker under hard acceleration. It isn't nescessarily a locker.
Old Mar 7, 2005 | 12:51 PM
Jeff92se's Avatar
I'm needing a caw
So what happens when the differential "acts like a locker" during a corner and hard acceleration? Because you don't want it to act like a locker then.
Old Mar 7, 2005 | 12:53 PM
when in cornering the differential supposedly acts like a disc type LSD
Old Mar 7, 2005 | 12:56 PM
Jeff92se's Avatar
I'm needing a caw
What is the % of the disc type?
Old Mar 7, 2005 | 01:01 PM
It doesn't specify
Old Mar 7, 2005 | 01:02 PM
did you check out the link?
Old Mar 7, 2005 | 01:06 PM
Jeff92se's Avatar
I'm needing a caw
Yup: Here is what it says:
The page you are looking for
has moved.
Old Mar 7, 2005 | 01:12 PM
go to mmrusa.com and scroll down to you see drivetrain columns on the left of the screen. click on differentials and it will pop up and show you all the applications for the LSD conversion.
ef9
Aug 14, 2015 03:03 PM
Supragte
Aug 12, 2015 10:00 PM
Turbo95Max
Mar 30, 2001 12:35 PM
Omegasrk
Nov 8, 2000 03:34 PM
Chebosto
Oct 10, 2000 09:03 AM
