Noise Noise Noise...WTF
Old 03-09-2005 | 02:34 PM
DaReaper9's Avatar
Sup Folks...
I thought I had come across a thread with this info in it, but I have searched and can't find it...
When I start my car in the morn, and the rpm's lower to idle, I hear a little rattle at the end. It only happens when you start it when it's cold, and only the first time you crank the car...Any ideas???
Old 03-09-2005 | 02:48 PM
Ammi's Avatar
350 Detroit Muscle
try tapping your accelerator to allow the fast idle solenoid to set.
Old 03-09-2005 | 02:49 PM
Sammzway's Avatar
What Ammi said ^^^^
Old 03-10-2005 | 07:04 AM
DaReaper9's Avatar
Would I need to do this every time I start the car?
Old 03-10-2005 | 10:10 AM
LA02MAX's Avatar
mine does the same thing...there's a TSB out on it...look here:
http://www.infinitihelp.com/Ownershi.../NTB03-060.htm
good luck on getting a dealer to fix it though, because mine does it every morning and i've left my car over night at the dealer twice and they keep saying they "cant reproduce the problem"...just find a dealer you like and trust (if there are any)
Old 03-10-2005 | 10:18 AM
DaReaper9's Avatar
http://www.infinitihelp.com/Ownersh...3/NTB03-060.htm
Thanks maxilvr06. Problem is, I am nearing 37,000, and no longer fall under the 3/36. Since this is not a recall, and only a bulletin, I would have to chew and swallow the cost of this...Would you happen to know? And Im pretty sure each stealership has their own labor costs...Thanks
Old 03-10-2005 | 10:21 AM
LA02MAX's Avatar
yeah, thats pretty unfortunate..im sure it wouldnt be cheap knowing the stealer...i have no clue how much if it would have cost if they would have done anything to mine, because i am under warranty...sorry i cant be of any more help...
Old 03-10-2005 | 11:22 AM
juniper9803's Avatar
You Guys Must Have ****ty Dealers If Vin Falls Into Tsb They Should Fix Mine Did With 45k On It
Old 03-10-2005 | 11:35 AM
Skier's Avatar
My 03' SE does it, and 03's are not on the TSB. With all the problems I've had with this car, as much as I love the looks and performance, I'm more and more convinced it's a piece of crap in general...
Old 03-10-2005 | 02:01 PM
ddh1313's Avatar
I feel your pain as I am experiencing the same problem (with both the car and the dealer). I am going to have to end up taking a half-day off from work to be present because apparently it only makes the sound when I turn the key. Its pissing me off beyond all explanation, but I suppose that I can understand why they do it if it comes down from the top as an order. I put my own post out prior to yours explaining my situation and many other org members replyed that they have gone through the same senario. It should be covered under the power trane warranty.
Old 03-10-2005 | 03:25 PM
TheBigDu's Avatar
I wouldn't describe it as a rattle so much, but I definitely have the same problem. Apparently the starter needs to be disassembled and greased? Sounds like a pain.
Old 03-10-2005 | 04:40 PM
DaReaper9's Avatar
Starter? Not the starter BigDu, and there's the link to the tsb a few posts up...If your starter sounds like this, then maybe you DO need another starter...Or maybe you need a new Max altogether
Old 03-10-2005 | 04:53 PM
TheBigDu's Avatar
Haha, I hope not. I guess it's the same thing as everybody else, I just though I'd read somewhere that is was the starter. But apparently I'm on drugs, because now I can't find what I was refering to.
Anyway, the only way I can see to get the dealer to replicate this is to leave your car at the dealer overnight, and take the key home. Then go back with somebody else when they're open in the morning and have them come out with you and you start the car. Just make sure it's a cold morning.
Old 03-10-2005 | 04:57 PM
DaReaper9's Avatar
...Anyway, the only way I can see to get the dealer to replicate this is to leave your car at the dealer overnight, and take the key home. Then go back with somebody else when they're open in the morning and have them come out with you and you start the car. Just make sure it's a cold morning.
and 2 add my .02 cents, I only get it the first time I start the car. If I immediately turn the car off, and then try to start it again, it will not happen again...So good luck to those who are taking it back to the a$$ership!
Old 03-10-2005 | 05:12 PM
ddh1313's Avatar
You have the (VTC sprocket) TSB issue... I am 100% sure. Have you ever been spinning something metal, like a wheel on an axle - etc., and it all of a sudden goes off balance and stops real fast.... thats the way it sounds to me personally. Just a real busy nasty metalic rattle and its the very worst on cold mornings or after it has been sitting several hours in the cold. It will only last for 1 or 2 seconds. It will almost never do it a 2nd time after you have run the engine unless its like 1 degree outside and you only ran the engine for a few seconds the first time. Plan on leaving the car at a dealer overnight and meeting them in the morning so that the bio electric unique energy in your body can be transfered through your fingers and the key and through the frame of the car and in turn cause it to make the sound since it never happens to Nissan employees. Oh.... and here is some more BS crap. The TSB only calls for them to replace the sprocket which they hear is causing the noise. SO... if you can talk them into replacing both Nissan recognized defective parts then you should be all set. If not, I suspect we will all be back in after a month or 2 for them to tell us that they cant duplicate the problem with the other cylinder bank's VTC sprocket. That will be about the time that I throw my over priced Starbucks coffee on the DSM's shoes and go buy a Toyota. Anyway...sorry for the venting guys.
Old 03-11-2005 | 08:05 AM
DaReaper9's Avatar
If so many people are having this problem, Im amazed that this hasn't reached a "recall" status...But then again, I guess they haven't received and logged enough call for it to reach that point. Speaking of which, I think Im gonna call..hehe...that'll be one more call to log...wishful thinking!
Old 03-11-2005 | 09:28 AM
TheBigDu's Avatar
I think for it to be a recall the problem has to be potentially hazardous to the life of the powertrain in some way, no? I'm not sure what this thing can do to the engine over time, but aside from being an annoyance, it's not really a HUGE deal. Know what I mean?
Old 03-11-2005 | 10:09 AM
ddh1313's Avatar
I think that it also has to pose a saftey risk to the public as well. The recalls that I have seen for the Maxima have been for suspension pars that, if they were to fail, could cause loss of control and then for the accelerator pedal stop in the 5.5 gen which says specifically in the TSB that it could cause an accident if there is loss of power at an unpredictable time.
Old 03-12-2005 | 01:06 PM
CoolMax's Avatar
is invisible
Same problem here. Have 50k on the car...suppose i should get this taken care of ASAP...if my dealer cooperates.
Old 03-13-2005 | 01:33 PM
Edward Lee's Avatar
Yo, our cars have a 60k engine warranty. If the sound is coming from the engine then it is covered.
Old 03-13-2005 | 03:13 PM
LA02MAX's Avatar
not with my stupid dealer! they were hesitant to cover it under the freakin 36K warranty!! i raised hell then they decided to take it in, but "never reproduced the problem" which is BS because it does it every morning!! like someone else says, i guess it only happens whenever I turn the key but they DEFINITELY wont cover it past 36K which im comin up on (35.4 right now)
Old 03-13-2005 | 08:04 PM
ddh1313's Avatar
Maxilvr06... on my first attempt to get them to fix this issue I asked to make sure that it was covered under the 5/60 and the advisor said yes "what ever that is worth".
Update on my effort to have this resoved:
On friday I took my car in my car in and explained to them that it will need to be started in the morning in order for this sound to be duplicated. The advisor then told me with a smile on his face that the first available 8am appointment would be the 26th of march or 3 weeks away. As he was scheduling the appoinment for me on his computer I made a call on my cell phone to my girl friend who left work early in order to pick me up. The second he realized that I was making a phone call he all of a sudden stopped what he was doing on the computer and yelled at me for me to give him my last name cutting me conversation off 3 times "having heard and being aware that the coversation was directly related to him and the dealership". So that was kind of the last straw. I called Nissan Customer Service and supposivly I am having some regional manager call me on Monday to work this out. I am not holding my breath needless to say.
Old 03-14-2005 | 09:42 AM
CoolMax's Avatar
is invisible
Are they trained to be unreasonable ******? I hope my future dealing aren't this bad or I have no choice but Acura/Infiniti/Lexus for my next car.
Old 03-14-2005 | 09:50 AM
LA02MAX's Avatar
well this weekend i'm going to bring my car in and leave it over night...then the next morning I'm going to drive alll the way into town and start it myself with the service manager by my side to prove to those IDIOTS that it actually does it!!! also today when i was driving to school, i heard the bose cut out on the left side so i put the speakers all the way to the left and they sound like ****...so needless to say, i have to go in and prove to them that the stereo isnt working either...i hate my dealer
hcarter1112
42
07-18-2022 04:35 PM
aw11power
10-10-2021 05:57 AM
D Mason
06-21-2016 05:43 AM
uttadms31
09-30-2015 06:24 AM
Quick Reply: Noise Noise Noise...WTF
