Camber kits for 5th gens!!!
Old Mar 10, 2005 | 07:07 PM
2kVQboodah's Avatar
so i dont see much people talk about this stuff... i think it's important!! can somebody start a little chat about these?? i just ordered my tein SS coilovers and i dont want my wheels slanted like riced out hondas...
Old Mar 10, 2005 | 07:34 PM
irish44j's Avatar
retired moderator
not a problem....I just saw Rob (dblrr90)'s car dropped 2.5+" and there is no camber problem. It only becomes an issue if you're really slamming it.
Stillen makes a camber kit, as do a few other companies, but not many people use em....not necessary with the maxima, our suspension is not the same as a civic....
Old Mar 10, 2005 | 10:39 PM
HNDA ETR's Avatar
Still Here... IM me for more..
yeah, i've got my SS Dampers sitting pretty low... I could go lower, but I'm not trying to scrape the road as I drive...
Long as you don't overdue it, you shouldn't run into any alignment problems...
Old Mar 11, 2005 | 03:18 AM
2kVQboodah's Avatar
are you using the EDFC with your teins hnda etr????
Old Mar 11, 2005 | 08:30 AM
Nissan SE-R's Avatar
Basically, you'd only need after the drop if the range of adjustment doesn't allow you to run the camber setting that you want. I have always used camber bolts at the very least (camber plates on the SE-R). I have pretty specific camber settings that I like to run, even if my car wasn't lowered. No matter what anyone says, a drop in suspension will affect camber and toe. Like some people have said, it may not be too bad depending on the drop. Still, camber settings can really affect handling and it's important to have them right.
Old Mar 11, 2005 | 05:03 PM
HNDA ETR's Avatar
Sure am... It's pretty cool... Unfortunately though, I only notice a change in suspension ride when going from the very softest setting and the very stiffest setting... I can't tell the difference with any of the other incremental settings.
Basically I have mine programmed for 3 different settings (for the 3 different memory locations) Totally stiff - 0,0 Totally soft - 16,16 and medium - 8,9
matts95max
Apr 23, 2025 10:44 AM
MAXSE5SPD
Sep 17, 2022 04:00 AM
Violator
Sep 9, 2015 10:14 AM
A32goldylocks
Sep 2, 2015 06:39 AM
Lowered_a33
Sep 1, 2015 07:49 PM
