VIAS help, please
Old Mar 14, 2005 | 04:41 AM
rule da road's Avatar
VIAS help, please
It seems i stripped the screw thats about 7o'clock. The others where quite easy with a vise grip. This gold metal rod is in the way and i cant clear to unscrew. I tried an impact but had no luck, what am i doing wrong?
Old Mar 15, 2005 | 08:26 AM
Its a wrap, i cant get the VIAS off. Anyone can explain the visual check of VIAS working w/o taking it off? When I punch 5k rpm my throttle wire to the left doesnt move while the right works fine. I have strong acceleration thru whole band in all gears, but have 80k miles.
Old Mar 15, 2005 | 08:28 AM
Safe to drive car with VIAS off? I was thnking of paying a mechanic down the block to take off.
Old Mar 15, 2005 | 01:42 PM
Komax's Avatar
Go to Home Depot. There's a nail looking pin called "Screw Remover". It has a spiral tip. There's also a "t" looking screw driver that spins the "screw remover". They are $3 and $5 respectively.
1. get a small drill bit and a drill to drill a small hole in the center of the stripped screw
2. then with a hole 1/4" inch deep, you jam the screw remover into the hole
3. turn counter clockwise with good torque and slow speed
it should come out
i did the same thing.
trailer54
Nitrous
Nov 18, 2015 07:44 PM
Turbonut
46
Oct 21, 2015 08:28 PM
King_Ten_Ahead
Sep 27, 2015 02:24 PM
Dasmith
Sep 23, 2015 08:28 PM
Kalrakam
Sep 16, 2015 12:30 PM
