HLSD Maintenance needed?
Old Mar 14, 2005 | 07:45 AM
SpottyJ's Avatar
I have an '02 Maxima w/ 6-spd and HLSD (Helical Limited Slip Differential).
Does the HLSD need to be serviced?
Maybe replace the oil?
If so how often?
How much have you been charged for this service?
Is the HLSD unit in the manual transmission?
If HLSD is w/ manual tranny then changing the manual transmission fluid changes the HLSD?
(Sorry, but I am a rookie in auto repair)
Is this a no-brainier as a home repair, or go to dealer as not worth hassle?
(I have done radiator flush and fill, spark plug and oil changes to give you an idea of my competency)
Thanks in advance for your thoughts.
Regards,
SpottyJ
Old Mar 14, 2005 | 01:17 PM
itdood's Avatar
The diff is part of the tranny. They share the same fluid.
Old Mar 14, 2005 | 02:08 PM
SpottyJ's Avatar
Thanks for the reply. The reason I ask is that the replacemnt of the Limited Slip fluid is listed seperatly, and at a differnt interval than the manual transmission.
See link for the service reccomendations at 30K. Again, thanks for the reply. I am just a little confused.
Select the 30K option from the pulldown:
Nissan Online Maintenance Schedule
Old Mar 15, 2005 | 08:23 PM
SpottyJ's Avatar
Thread bump... thanks.
I am still not sure why the service for Limited Slip Differential is on a different schedule from the Manual Transmission if they share the same fluid. The Limited Slip Differential is listed right before the manual transmission service.
Bottom line, tomorrow (Wednesday) I am going to dealer for some service and I want to make sure I understand what I need/don't need.
THANKS
Old Mar 16, 2005 | 06:02 AM
SpottyJ's Avatar
Still need some advice...please!
Last bump... I would appreciate some advice
(Thank you to "itdood", but, I am still confused.)
Bottom line, today I am going to dealer for some service and I want to make sure I understand what I need/don't need.
On my truck (I know different vehicle) the differential is not integrated with the Tranny fluid.
THANKS
Old Mar 16, 2005 | 07:28 AM
Puppetmaster's Avatar
I would check my FSM.... but it isn't on me right now.... hopefully someone else can answer your question... although it doesn't seem like anyone knows...
Old Mar 16, 2005 | 08:50 AM
reygarcia's Avatar
Loved by MrGone longtime
the fsm doesn't show a procedure for servicing the hsld. i have looked through it 3 times and found nothing other than the diagrams. i just recently put some redline mt-90 in there and haven't had any problems.
i think the servicing at 30K is just another way for the dealer to make money.
Old Mar 16, 2005 | 08:59 AM
I just skimmed through mine too... couldn't find it either...
Old Mar 16, 2005 | 09:05 AM
CCS2k1Max's Avatar
IIRC, someone had this same question in the fluids forum a couple of years back. It seems that Nissan missed a footnote on that item. Basically, If your difterential has a separate case, i.e., a RWD or AWD, then there's the need for be a separate schedule. However, the LSD in our cars (well, I wish on mine) is in the same transmisson case, so the argument is moot.
I run MT-90 on mine, it's better but the shifts are still notchy.
Old Mar 16, 2005 | 09:09 AM
Thanks for the info man...
Old Mar 16, 2005 | 09:11 AM
CCS2k1Max's Avatar
No problem.
Old Mar 16, 2005 | 10:14 AM
SpottyJ's Avatar
Thanks for clarifying. I will report my service results.
Old Mar 16, 2005 | 02:01 PM
SpottyJ's Avatar
Well I went to dealer and Service Writer insisted it was a seperate service for replacing the HLSD fluid from the manual tranny. I asked the service writer to check with a mechanic, mechanic verified what was siad here - they share the same fluid. Thanks for the info, if I was not informed I am pretty sure the dealer would have billed me for for both services.
Old Mar 16, 2005 | 02:26 PM
CCS2k1Max's Avatar
Information is power (and those ***** hate the internet). I wonder how many unsuspecting, trusting people, in their ignorance, get taken to the cleaners. Glad it worked out for you.
Old Mar 16, 2005 | 03:28 PM
SpottyJ's Avatar
Hey, one more question, this "stealership" wants $125 for a manual transmission drain, I agreed and left. I later called two other dealerships and they quoted $75 for the same service.
What are your pricing experiences for a manual transmission service?
Old Mar 16, 2005 | 05:29 PM
reygarcia's Avatar
changing the tranny fluid will take you no more that 1 hour (taking your time) and the cost of the tranny fluid and funnel + hose. plus you will learn how to do it yourself.
here is the link
housecor's writeup
very, very, very easy to do.
edit: AIM me if you have any questions
Old Mar 17, 2005 | 04:26 AM
SpottyJ's Avatar
Thanks for all the help, in particular the link to how you do it your self.
I picked up the Max today. Bottomline was $69 for M/T drain and fill.
Old Mar 17, 2005 | 10:34 AM
reygarcia's Avatar
For about a third of what you paid, you could have gotten the Redline MT-90
Old Mar 17, 2005 | 10:36 AM
CCS2k1Max's Avatar
That's an exageration. It's closer to two thirds.
EDIT: Daim, you are right Rey, it is closer to half, esp. with the coupon. Take it back.
Old Mar 18, 2005 | 03:31 PM
reygarcia's Avatar
yup, myoilshop.com pwnz all
Old Mar 18, 2005 | 06:41 PM
Out-of-Focus's Avatar
It's a shame most service advisors don't know jack about servicing cars. If it was up to me I would speak to the customer directly, but it isn;t.
The HLSD sould be "Serviced" at normal manual tranny service intervals, cant remember off hand. All it is is a drain and fill. Any dealer that charges more than 1/2 labor are crooks.
Old Mar 19, 2005 | 12:46 PM
SpottyJ's Avatar
Thanks for the reply, are you saying the HLSD is a separate sevice from drain/fill the manual transmission?
Old Mar 19, 2005 | 10:35 PM
reygarcia's Avatar
on paper it is a separate service
15K it says to drain and fill HLSD
30K it says to drain and fill tranny
why is there is no drain and fill at 30K for HLSD??? just another way for them to get your money.
VQ'ed
69
Aug 27, 2020 12:29 PM
smplyamzng
Dec 13, 2015 01:19 PM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
TonyJr
Aug 20, 2015 12:14 AM
