Recommended rotors and pads
Old Mar 19, 2005 | 09:01 AM
Lumbee1's Avatar
I need to replace the front brakes on the Max. I need to know if I should replace the rotors only with aftermarket, pads only with aftermarket, or both the rotors and pads with aftermarket.
The 2k and 2k1 Maxima had a rotor warping problem. My 2k2 appears to have a material transfer problem. It looks as though the pad has gotten hot and greasy and part of it has stuck to the rotor surface. I do not autocross or even drag the car so this is not due to extreme usage. I don't know whether this is a pad problem or a hot rotor problem.
I am considering frozenrotors.com or brembo blanks (or slotted). For pads, I am looking at Hawk HPs pads or Axxis Metal Masters.
Old Mar 19, 2005 | 09:39 AM
adithius's Avatar
Brembo blanks are good rotors. For pads, your sugestions are good and they stop well, however they make a lot of noise (squeel). I'd recommend stock pads, or Raybestos Quient stop ceramic.
Old Mar 19, 2005 | 10:36 AM
Lumbee1's Avatar
I have a set of stock pads NIB. The problem is that stock pad have smeared material across the rotor. Now is this a problem with the rotor retaining heat or the pad material?
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
MaxLvr21
Oct 17, 2015 12:11 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Socalstillen
Sep 26, 2015 12:01 PM
