Problem with H&R Spacers Install
Mauja He Mauja
I followed the directions here.
http://home.insightbb.com/~davidwhon...cer/spacer.htm
But i can't get the longer studs to stay put. They are wiggling, I can't put on the wheels cause they push back. Seems like the new studs are thinner than the OEM ones. I can't put back the oem ones, since the threads are messed-up from hammering them.
Any ideas??
Any ideas??
Were the new studs hard to press into the hubs? If not, you have the wrong ones. When I got my spacers a couple years back, H&R sent me the wrong ones too. I had to have them send me the right ones.
The new studs should have been very hard to put in BTW.
Mauja He Mauja
I ordered the 20mm and I just checked the box. They are 40mm. Had to call a friend and get 5 new studs from autozone. Fuqing wasted the whole day, and my back is killing me ... But did put back on the millies
Mauja He Mauja
I am hoping someone here can post the item #. Obviously the ones I got are not the correct size. I am going to contact Justin and see what can be done. The spacers were bound together will some tape which read : "they cannnot be returned if they are installed". My stupid **** should have checked the box, prior to installing them. But after waiting for 6 months, I was too excited.
So who here has 20MM H&R's? Please post a pic of the box showing the item# and description.
I have 20mm H&R spacers. I'll post a picture of the box tonight when I get home...or at least let you know the P/N.
When I installed the new studs I could not get 2 (out of 10) of them to stay put. When I put the wheel on and then tried to tighten the lugnut the studs would get pushed back throught the hole and touch the hub assembly. I had to take the wheel off twice to get them to stay put.
What I did was get a couple spacers and put them over the stud. Then I hand tightened the lugnuts on the studs (with the wheel still off) and tightened with the wrench to force the head of the studs through the holes on the hub. After I did that I re-installed the wheel and got all the lugnuts to tighten on the studs.
Mauja He Mauja
Originally Posted by Kevin
do you know what teh shoulder diameter of the studs are? is shoudl be 14.25 mm , it might be that they sent you the wrong should length studs.. let us know how it goes.
here is info on the studs from optionimports.com:
Stud, Thread Type: 12x1.25.
the ones i have are 12x0.85.
did you pick up replacement studs from autozone that were the same as OEM or longer?
Mauja He Mauja
justin e-mailed back and said the replacement will be shipped in 4 days.
the studs from autozone were 0.98 a piece. they ae the same size as the oem. not sure about the quality.
so for all who will do this, don't beat the crap out of the oem studs. hold a folded towel, and then beat on the studs. you never know, you may need those again..
From the box of my 20mm spacers...
Automotive Wheel Spacers DRS-System 40mm 114, 3/5, 66, 2mm
NISSAN
incl. 10xDRS-Bolts 12255024(H44), Shoulder 14, 25mm
Stock: 07-D 15
Item No: 4065662
Hope this helps.
NISSAN
Stock: 07-D 15
Item No: 4065662
Hope this helps.
Mauja He Mauja
NISSAN
Stock: 07-D 15
Item No: 4065662
Hope this helps.
NISSAN
Stock: 07-D 15
Item No: 4065662
Hope this helps.
mine read:
NISSAN
incl. 10xDRS-Bolts 12265024(H49), Shoulder-012,85 mm
Stock: 07-D 15
Item No: 40656621
thanks for your help
Mauja He Mauja
thanks fezzik. i even e-mailed you on your yahoo account for this.
the details from fezzik:
10xDRS-Bolts 12265024(H44), Shoulder-o14,25 mm
the details from GaMax97GLE:
from mine:
the details from mine and fezzik are similar prior to the (H44) part
from mine:
SmokinMax02
18
09-11-2015 12:25 AM
Maxboy23
08-11-2015 11:59 AM
kirkhilles
08-08-2015 10:53 AM
