Somebody Please.....
I HAVE RECENTLY BOUGHT a 20TH ANN. MAXIMA and the damn bose system rattles,there seems to be a little noise in the passenger side dashboard everytime i hit a bump(sounds like somethins loose,little rattle)......ive seen a few people havin the same problem in other posts.....but someone.....i need to know why the hell the Bose system does that....Bose IS NOT SUPPOSED TO DO THAT.
In the TSB Sticky thread there is a Technical Service Bulletin on rattles. If you read that TSB you'll understand that Nissan gives their technicians the ammunition to fix those rattles. Point them out to you dealer when you have it serviced the next time.
I have the same Bose problem in my AE. <<here comes a rant>> First, it is my personal opinion that all in-car Bose systems are worthless pieces of junk with too much muddy bass and not enough midbass. <<end of rant>> Second, the Nissan fix is little spongy pads between the package shelf and the body. That will (may) eliminate the rattle. However, the source of the problem is a flexible package shelf with no sound/vibration deadening material. I believe premium (thick) Dynomat applied liberally on the underside of the package shelf (difficult to do) would be a better cure of the symptom than Nissan's cure. A better cure would be to reinforce the package shelf. My thoughts are wood and/or fiberglass reinforcement although I have no idea how to do either.
Hope that helps and let us know what you do if you use a solution above and beyond Nissan's.
Thanx guys......i used the search feature and discovered the whole velcroy process ....that might work(using velcroy to hold the pads surrounding the sub).....i will mention it too my dealer also....and maybe that might completely rid all rattling....but u know,i really thought Bose systems were like the greatest,until now that is
Originally posted by yongjun
I noticed this weekend the bose rattles.
But i also like the bass sounds.
So it doesn't bother me much.
Screaminfast
Jun 25, 2001 04:58 AM
