Last minute 36k warranty check
Old Mar 23, 2005 | 11:19 AM
QUADRO's Avatar
Can anybody inform me of whether brake judder problems exist with 2002 Maximas? When I drive over 60 and brake I do feel "judder" and don't know if it is a problem or not. I'm at 35,500 miles and want to get the car covered for any problems before the warranty runs out. Are there any other serious costly issues that I should look out for? The radio has been changed 2 times already and the front driver seat was fixed once. ANY input would be great....got about 7 days before warranty runs out.
Old Mar 23, 2005 | 11:49 AM
kidkay's Avatar
I'm experiencing the same problem, but i'm too lazy to check out the problem. does not really bother me...i rarely quick brake at that speed. chk out this link below, i hope it helps:
http://forums.maxima.org/showthread.php?threadid=36539
its could be a TSB problem, Orgers correct me if i'm wrong.
Also, check this link out by Lumbee799....
Originally Posted by Lumbee799
Full Brake Rotor TSB!!!
Finally updated my website and uploaded 5 pages of the Brake Rotor TSB in jpg format.
http://apollo799.50megs.com/Maxima/Maxima.htm
Old Mar 23, 2005 | 12:51 PM
BatMax's Avatar
I believe there's a brake rotor TSB. And I read somewhere that the rotors are all covered under the warranty. See if you can get them all replaced...heh heh. I had my rears replaced.
Old Mar 23, 2005 | 12:52 PM
scopium
if the dealer is nice. they'll probably do it under warranty..
but usually brakes are under the 12k warranty
Old Mar 23, 2005 | 03:32 PM
grey2002_ny's Avatar
I have a 2002.. you have warped rotors... they will probably just resurface them for free, if it's still under warranty. They may also jerk you around and say that you need new brakes etc.... The 2002 and a few other years have defective rotors that warp. I had mine replaced at 30,000 and I need to have them done again at 45,000.
Old Mar 24, 2005 | 06:56 AM
QUADRO's Avatar
I Guess If They Are Defective And They Shake When You Brake They Should Def Be Covered Under 3 Yr/36 Mo Warranty.
Is It Bad To Resurface Rotors To Fix A Warped Rotor? Should Be Replaced.
Mar 12, 2020 12:06 AM
RWCreative
Sep 21, 2015 11:01 AM
tardrex
Sep 11, 2015 07:35 PM
conansriver
Sep 11, 2015 10:26 AM
Maxima30
Sep 7, 2015 06:13 PM
