Can someone double check this? [PICs of FTSB]
Old Mar 24, 2005 | 10:00 AM
PTP's Avatar
PTP
So I just installed a FTSB and I had a few questions.
One the passenger side, it is sitting really close, literally on-top, of what I believe is the AC recharge line. Is it supposed to be this close? And if so, is this safe? http://ahsan.fotopic.net/p13033161.html It looks like its touching but its actually not. Theres about enough room to slide in a sheet of paper, ya so not much.
This next one, I had to flip the Swirl Control/Valve Control/Vacuum Check Switch as mentioned in the write-up. The wire seems like it just made it. Did I do this right? http://ahsan.fotopic.net/p13033163.html
For the overall effect: http://ahsan.fotopic.net/p13033165.html
Thanks all.
Old Mar 24, 2005 | 10:02 AM
GBAUER's Avatar
The driver's side looks fine, but I'd get a couple of washers under the passenger's side. I bet it rubs when the engine torques.
Old Mar 24, 2005 | 02:14 PM
slizan99's Avatar
looks fine. just bend the a/c line's bracket down for more clearance.
Old Mar 24, 2005 | 02:26 PM
spiromax's Avatar
Seoul Man
Oddly enough... my FSTB doesn't have that problem, because that line is nowhere near it. Maybe it's just routed differently on the VQ35-powered Maxima.
Old Mar 24, 2005 | 02:49 PM
PTP's Avatar
PTP
"bend"? is that safe? I wont break it. Can you explain this a little more.
Old Mar 24, 2005 | 06:52 PM
slizan99's Avatar
the bracket is made of thin metal. bend it down a little. it will be fine.
Old Mar 24, 2005 | 07:02 PM
frankd121's Avatar
it'll be fine...mines pretty close and i haven't had any problem
Old Mar 24, 2005 | 07:38 PM
Puppetmaster's Avatar
Like George said... stick some washers under the brackets... should be a good enough fix...
spidgeon
Sep 9, 2015 03:36 PM
Violator
Sep 9, 2015 10:14 AM
crazyespn
Sep 3, 2015 01:30 PM
