what went wrong?
Old Mar 26, 2005 | 05:38 AM
yogi's Avatar
what went wrong?
So yesterday i`m leaving my gf house...start the car...i let the car warm up(chicago weather sucks)....give it some gas....and nothing....the car would idle fine but as soon as youd give it some gas the rpms wiould climb to about 1200-1300 rpm and that's it....even at full throtle.......i gave it some time and about 30 minutes later the car started with the SES light on, but drove fine....got me home....so i get into my car today and it will not start.....well it starts and then it dies right away.......do u guys know what the heck is going on....is there an easy fix to that? i really need the car for this weekend(easter and stuff)....Thanks
ITs a 03 max with 32k
BTW Have a nice/happy Easter
Old Mar 26, 2005 | 05:41 AM
ChromeSE5's Avatar
maf.... you can unplug it and it should run into limp mode(cant go over 2500 rpms)
Old Mar 26, 2005 | 05:43 AM
yogi's Avatar
that's what i tought last night....the MAF(after reading about it on the forum) but at 32k? that's kinda fast.....do u think that MAF is also causing the car to shutdown right away?
Old Mar 26, 2005 | 05:47 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Maf and that's a big problem on the 02-03..., hopefully you can find one soon..... call Daveb 1-888-254-6060 if you can wait.. if not might have to go to your near stealer.... and they will rip you off.. You only need the MAF not the tube.....
Old Mar 26, 2005 | 05:51 AM
yogi's Avatar
stealer huh...... hehehe
i guess then that it's not covered under warranty
btw...do u know how much MAF will run me?
Old Mar 26, 2005 | 06:24 AM
yogi's Avatar
so i just talked to nissan and have the appointment on monday....they r saying that if it is a MAF it's going to be covered under warranty.....now if it's not i`m out $100 to get the car towed to dealer + $95 for inspection(or something)
the STEALER is a rip off - $488 for a friking MAF sensor.....that is some sick *****
Old Mar 26, 2005 | 08:43 AM
2K3MAX2NV's Avatar
"tse-tse fly"
did you check your air filter just in case?
Old Mar 26, 2005 | 08:49 AM
NYPD-Arnold's Avatar
Z
Yeah, avoid the stealership. It should cost no more than $150.
Old Mar 26, 2005 | 11:18 AM
Lontar1's Avatar
If you buy the 01-02 new update it shoul run around $90.00 shipped, you can install it yourself cause it is really easy.... DONT TAKE IT TO THE STEALER..... but if you are under warranty let them figure it out....
Old Mar 30, 2005 | 06:37 AM
yogi's Avatar
so here is an update on that.....the car has been at the STEALER for the past 2 days....he pulled a couple codes....and doesn't think that the MAF went wrong(or is going out) he's leaning torward the Throttle Plate(or something like that) failure.....also he said that the air filter that i have in the max(air hog....from air fram) is restricting the airflow to my car(that confused me)...what do u guys think?
Old Mar 30, 2005 | 07:14 AM
2K3MAX2NV's Avatar
"tse-tse fly"
Like I said I had the same problem due to my K&N being dirty as hell we need to keep that thing clean at all times
Forge277
Jun 13, 2016 09:26 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
pears
Sep 18, 2015 05:25 AM
