damn stealership
Old Apr 2, 2005 | 01:17 PM
xlcrew's Avatar
I’m Back
damn stealership
i went today to have my ecu reprogram for my new maf and they wanted 160 bucks to do it i told them they were full of **** and walked out, so i guess i need to know if i can hurt anything by not having the reprogramed the car runs fine from what i can tell
Old Apr 2, 2005 | 01:20 PM
NismoMaxm's Avatar
Check out CM. They have an ecu program:
http://www.customenterprise.com/view.../vts/design004
Old Apr 2, 2005 | 02:01 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
just let the negative from your battery disconnected for at least three hours... you should be fine...... the ECU reprogram is not necessary at all... I call DAVEB and he told me that.....
Old Apr 2, 2005 | 02:11 PM
NismoMaxm's Avatar
i thought he wanted to reprogram it to get more power and stuff?
Old Apr 2, 2005 | 02:25 PM
irish44j's Avatar
retired moderator
NO!
This is a POS and will not do anything for your car.
Old Apr 2, 2005 | 03:06 PM
nyautostyle's Avatar
^^^ irish is right, that ecu chip does nothing to your car.
I would check under how-to's..
http://maxima.theowensfamily.com/ecu.asp
Old Apr 2, 2005 | 03:25 PM
Epacy's Avatar
Unsuccesful STL Coordinator
I think if you are a 00-01 and get the new MAF that you do need the ECU reprogramed.
Old Apr 2, 2005 | 08:11 PM
rule da road's Avatar
I have a new MAF on my 2000, feels great but I've had an intake for months w/o a SES. I keep resetting the battery overnite to keep getting a P1130. Searched all over but couldnt find any answers on the org. Autozone says too much air flow to the engine. Now I do believe the ecu reprogram will clear this code for it accomodates for these mods. Like hypergrounding, the reprogram should allow for things to run a little better with modded max's. And I was also quoted $150 for the work, crazy u kno.
Old Apr 2, 2005 | 08:35 PM
MCE's Avatar
MCE
They are reaming you for reprogamming. I paid 45$ CAN. and it took about 30 min. Find another dealer that is at least half honest.
MCE
Old Apr 3, 2005 | 10:39 AM
Teufelhunden's Avatar
you talking about this? ive done this after i installed an intake, i dont know how to do the throttle valve closing, but this was posted loooong time ago. hope this helps. http://www.technosquareinc.com/350reset.htm
Old Apr 3, 2005 | 11:26 AM
Puppetmaster's Avatar
I'm pretty sure that's only for 02-03s... its the same one as in the FAQs/How-Tos...
Old Apr 3, 2005 | 11:27 AM
When ya install a new MAF, the reprogramming of the ECU is not the same as getting an aftermarket reflash... which seems to be what you have in mind...
And like everyone said... JET chips do nothing for us....
Old Apr 3, 2005 | 02:16 PM
Menasor's Avatar
Some of you, I take it from yor replys that he is talking about resetting the ECM. He is talking about a reburn/reprogram. When you buy a new MAF (00-01 5th gens) you get a note recommend a reburn and it tells you the exact burn that you need. I got qouted $83 dollars, I would go to another dealer. $160 is too much IMO.
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
DrVee
Sep 4, 2015 12:18 PM
Vitaly O.
30
Oct 29, 2000 12:23 PM
impossible2stop
Oct 28, 2000 11:31 AM
