5.5 Gen owners, hows our MAFs?
okay i've been running the berk/apex-i setup for awhile now.....i'd say around 5k or so.....but I would like to know if our MAFs will throw a code on the SES if it goes out? I know the 4th gens have a knock sensor code that is a "ghost" code....was wondering if the 5.5 gens are like this?
my car seems fine....i don't feel a low end lose.....i can't really tell about my top end becuz i'm so use to the power of my car that I can't even tell...haha....but on the reals though....how do our MAFs adapt to the car when it goes out?
I do have a SES light for P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)....iirc, sensor 2 means its the DOWNSTREAM o2 which only moniters catalytic converter efficiency...not my a/f ratio....so my car wouldn't lose hp becuz of this SES right? like it wouldn't perform any better/worse if i don't have this code correct?
Don't know if it'll kill performance (the O2 sensor), but it'll probably effect your emmisions. If you have to get your tested (or if the light gets annoying), change the sensor. As far as your MAF goes, I've used my Injen now for 30k miles and haven't had a problem (my '03 has 108k). Just don't over-oil your filter.
The MAF issue doesn't always trip a code... many people have blown their MAFs with no codes coming up.... besides, it sounds like your car is driving relatively normally, so it couldn't be a dead MAF....
I have a Berk/K&N and have had it for 5k miles now and everything is fine... apparently, us with K&Ns were supposedly at higher risk since we have the infamous oily filters... but a MAF will die regardless of whether ya have a stock filter, K&N, or Apexi... the oily ones just increase the risk...
Did you guys all use the 02-03 ECU reset procedure after you installed your intakes?
I'm about to install an Injen within the next week, however, i'm unsure whether to just not reset the ECU, in order to make it think the stock airbox is still in place to allow the same air/fuel mixture settings to be used. Or would it be better for the MAF if I reset the ECU to allow for the changes in the increased airflow? I'd just like to know if resetting the computer for it to adjust it to the intake's increased airflow will put a greater strain on the MAF, and eventually lead to total failure.
http://forums.maxima.org/showthread.php?t=393596
Originally Posted by spiromax
I posted something you might want to read about having an intake and resetting the ECU. Nobody will reply to my thread, though... I guess it's too long, and people don't like reading.
Thanks spiro, that's very useful information. The problem your having is basically whats on my mind in terms of resetting the ECU or not. I feel as though leaving the ECU alone may have a better effect on idle and the longevity of the MAF sensor. But on the other hand i'm thinking by not resetting the ECU, optimal gains may not be reached from the intake due to fuel being drawn in at factory settings, and not matching the increased airflow of the intake. But when it all comes down i'd rather sacrifce optimal intake performance over a blown MAF sensor anyday. I'm just waiting for others to chime in on whether they reset the ECU or not.
so do u know if MAF will cause top end problems? i'm kind of worried becuz you said a blown MAF sometimes doesn't trip a SES....so my top end could be fu*ked up without me knowning...
I wonder about my top end too. My bottom end seems OK now. I had a few issues when I first got my car. My car seems to lay down above 80 mph. Steven knows about my MPH issues at the track which I hope are due to low octane.
Let me know what you find out,
Gears
Gears
Honestly gears....I think your car is very healthy....from the threads you posted awhile back....and since u were running low octane...it would get even more healthier with 91+.....
The reason why I'm concerned is becuz I recently did a pull against my friend's WRX 5spd. The story can be found here http://forums.maxima.org/showthread.php?t=393271 .....anyway I've studied the WRX for about 4 months now....so far from what I learned is their stock TD04 turbo suffocates like mad after 5500 revs....and me and him raced till 130ish...thats basically ALL top-end and he pulled a car in front of me....granted he has more mods and weighs lighter than me....I still thought a 6spd max would pull becuz of their awesome top-end....which leads me to think if something is broken.....
Dont know if this is a MAF issue but ive been having some power loss issues, sometimes i start to push my foot down and it accelerates so slow, like my old 4cyl, and ive been gettin a rotten egg smell from the back of the car. Ill be replacing it soon to see if its a MAF problem.
I did not reset my ECU after installing my Berk.... car run fine then and it still runs fine now. I did unplug the battery for the hour I took to install it, but I don't consider that resetting the ECU.
See this link from the FAQs:
http://forums.maxima.org/showthread....21#post1173121
As for my MAF, it has been dying and it got to the point where the car woulnd't keep an idle at start-up. So I had my dealer replace it under warranty. I've been running a stillen popcharger since I got the car. So I'd say my MAF lasted almost 90,000km's.
Finkle
Sep 27, 2015 09:53 PM
MikesChevelle
Aug 19, 2015 07:19 AM
MaxStock
Aug 14, 2015 10:03 PM
