5.5 gen homemade hyperground kit
Old Apr 3, 2005 | 10:04 PM
tothemax319's Avatar
Hey guys.. I'm planning on making my own 8-gauge hyperground kit for my '02. I've seen irish's detailed write-up, but I am wondering if the ground wire mounting points on the 00-01 VQ30 are the same as the 02-03 with the VQ35. Any info, tips, or tricks regarding the install would be much appreciated. Thanks in advance.
Old Apr 3, 2005 | 11:24 PM
steven88's Avatar
Need A Light?
I did the Blehmco grounding kit on my car.....the vq30&vq35 are pretty damn similiar if you ask me....as far as ground points go......so yeah...basically you want to get the important ones...such as the neg battery, alternator...and the two points on the passenger side of the engine....u have to remove the engine cover in order to see this.....but anyway maybe try adding two wires to the negative terminal....and two wires to the alternator then ground all of them.....i've only done 1 wire of each....it helps....but i heard the more wires it frees up more.
Old Apr 3, 2005 | 11:46 PM
Arek's Avatar
I'm planning on making my own hyperground kit for my car to but I have a question what's the difference in using 8-gauge, 6-gauge or 4-gauge wire
Old Apr 3, 2005 | 11:52 PM
Thanks Steven, i'm using irish's how-to as a reference point, and just was curious if anything is different on the VQ35 that wouldn't be shown on his write-up for the VQ30. So if the mounting points are similar on both motors as you stated, then the install should go smooth and accurate. Also, double wires to the alternator and negative battery terminal sounds like a good idea, I think I may even try running 4 gauge wire in place of the double 8 gauge wires.
Old Apr 4, 2005 | 01:17 AM
maseo77's Avatar
Where is irish's write up on this? got a link
Old Apr 4, 2005 | 03:30 AM
Liquid_pjear's Avatar
Most audio people upgrade the big three power wire with 0 gauge wire which is what I plan to I may use it for the major grounds as well. It is overkill for grounds but I have extra. You should be fine with 8 guage but the quaity of the wire can make a difference. I plan to use very high quality audio wire.
Old Apr 4, 2005 | 06:25 AM
NISMAX03's Avatar
I did my hypergrounding a while back. I used the following link to guide me:
http://www.cardomain.com/memberpage/313259/10
Old Apr 4, 2005 | 09:16 AM
Thanks.. That is bascially what I was looking for in the first place; a write-up for 02-03's.
Old Apr 4, 2005 | 09:19 AM
steven88's Avatar
Need A Light?
that cardomain website should be made into the HOW TO's...i know irish's HOW TO is listed in there....but 02-03 owners might get a better idea from this write up....since both of the engines are 100% identical looking
Old Apr 4, 2005 | 02:43 PM
Epacy's Avatar
Unsuccesful STL Coordinator
4 guage if making your own. Do it.
MAXSE5SPD
Sep 17, 2022 04:00 AM
Violator
Sep 9, 2015 10:14 AM
A32goldylocks
Sep 2, 2015 06:39 AM
