To Those with LED Turn Signal Mirrors
Is their anywhere inside the cabin I can tap into the signal wires?
I dont really feel it's necessary to run wires under the hood....
Any help is appreciated.
Can you not tap into the fuse box or the turn signal stalk (steering column)?
I haven't looked under there, so i'm not sure what options there are. Just wanted to make sure you've exhausted those options.
If you can find the fuses inside the cabin that controls the signals you can probably tap into the wires from there. I don't think it might be necessary to go into the hood area, but I might be wrong. I will check mine out to see for sure.
And one more thing I would'nt mind getting some of those mirrors with the turn signals on the mirrors like on the Mercedes. I don't know of any yet except the ones you slip over the back of your current mirrors.
If anyone finds that writeup, please post it here. I have done a search and was unable to find anything.
You can purchase the mirrors from: www.redlinemax.com
Got it follow this link.. hope this helps..... this is the one I'm using to add mines.
http://www.cardomain.com/memberpage/526558/6
Hey Igor, how bout locating the bounded wires running from the rear of the car towards the engine bay. Probably in the door sill. Just locate the wire coming from the tails and splice into it as it passes the cabin. I was looking at the wires yesterday in the trunk where the trunk sill is, and if i'm not mistaken, looks like it's running down the passenger side of the car.
You can run the wires to the back of the guages, the wires are color coded, real easy if you have the wiring diagram. The most difficult thing for me was I stripped the screws at the bottom of the mirrors so I wasn't able to run my wires through it. I had to drill a small hole through the side of the black part and run the wires through the doors under the center console to the back of the guages.
I ran mine right next to the thick harness that goes between the fenders and the splash guard. Started from the turn signals by the headlights and ran it on the harness all the way to the door where the harness goes in. Simple and quick.
I tried to use them and they make the relay go crazy, when the turnsignal is off, it makes the relay think that the hazards are on. This will fry your relay!!!
I sat there for an hour testing diff wires. Ground BOTH wires to the thick black wire, then connect LEFT to green/white and RIGHT to green/yellow.
I THINK thats how I got it to work. I can't remember
Originally Posted by Igor911
THESE INSTRUCTIONS ARE INCORRECT!!!
can you re think what you did I don't want to Fu$k my car..... thanks
If i ever do take it apart in the near future, ill post it in this thread
I think i posted the right stuff...Im not going to take my dash apart just to confirm.
chernandez1278
Sep 16, 2015 01:18 PM
BrandonCause
Sep 14, 2015 10:41 PM
