Weighted shift knobs
Old Apr 5, 2005 | 12:12 PM
Maxima-Ness's Avatar
Weighted shift *****
Okay, so Im at work and bored. Anyway....I got to looking around and doing some investigating on the weighted shift *****. I figured I was getting the STS, might as well look at a ****. But what are the benefits of a weighted shift ****? does it just help with the throw? Ive been looking online for one to work with our 6spds, but I cant seem to find one because of that damn reverse lockout!
comments?.........
Old Apr 5, 2005 | 12:30 PM
Y2KSESteve's Avatar
The heavier shift **** does definitely help getting the car into and out of gear. I use a Greddy counterweight shift **** and I love it. I know Skunk2 released their weighted shift **** for the 6 spd Acura/Hondas and that one is heavier than mine..
Old Apr 5, 2005 | 12:35 PM
so do they have one thats compatable with the 6spds w/reverse lockout?
Old Apr 5, 2005 | 02:17 PM
ColdSHO's Avatar
i made one for my car, i just bought one that has the led's inside and took them out and put a weight in. i used soem wierd metal thats super heavy, it made shifting easier with my short throw. deffently recommend it!
Old Apr 5, 2005 | 02:39 PM
well, im not too technical, so I was hoping that someone knew of a place to get one.....
ill keep waiting....
Old Apr 5, 2005 | 07:54 PM
lex3015's Avatar
my shift **** is nokya, its got a nice feel and def alot heavier than stock. i got it at a local spot i go to for most of my aftermarket needs.
Old Apr 5, 2005 | 08:59 PM
Sly's Avatar
Sly
Hopefully you all won't have the same problem I had. I used to have a nice heavy shift **** on my STS but after a couple years the bushings in the shift links wore a little and loosened up. I ended up with a slight rattle. So I put the stock shift **** back on and problem solved. Must've been some sort of weird harmonic since you would think adding weight would've dampened the system, but it ended up the other way around.
Old Apr 6, 2005 | 06:06 AM
Okay, my next question is....do they make anything to add weight to an aftermarket shift ****? Or...is there a certain item you can buy and add to the inside of the **** from like home depot or something?
thanx
Old Apr 6, 2005 | 07:43 AM
Kruppa's Avatar
The Skunk2 is 440 Grams which is 15.5 oz and the Greddy is 13.5 oz so the difference is very slight and probably won't make a difference, not to mention the Skunk2 is horribly ugly.
Old Apr 6, 2005 | 08:14 AM
yes, the skunk2 is hideous!
Old Apr 6, 2005 | 08:16 AM
course, the Greddy ones are ricey......
Old Apr 6, 2005 | 10:53 AM
Y2KSESteve's Avatar
How do you figure?
Old Apr 6, 2005 | 10:58 AM
frankd121's Avatar
I should get a heavier shift **** for my sts, but there aren't any good lookin ones out there...
Old Apr 6, 2005 | 11:01 AM
Originally Posted by Y2KSESteve
How do you figure?
cause all the little civics I know around town have them, so that qualifies. And it just has that "As Seen in the Fast and Furious!" look to them. Blah!
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
atriuum
Sep 28, 2015 01:19 PM
