How to take out the radio
i know its been posted i just dont have much time and wanna know if any can give me the blue print pic of how 2 disassemble the middle dash so i can take out the radio
thanx
thanx
take off shift ****
remove plastic shifter trim
unplug hazard/cig lighter
take out change/ashtray sheath and remove screw
pull out air vents on top of stereo
two screws on top, two on bottom
bang.
luxbond is not responsible for broken, scratched, lost and damaged trim pieces or electrical fires associated with the above procedure.
bang.
Try this link:
http://www.carstereohelp.com/stereor...NisMax3Str.htm
It is rather easy if you have an auto you dont have to remove the shift **** only stick's. Make sure that when you pop the vents on top you dont use a screw driveer or you will scratch the shat out of them same with the botom shifter trim. I dont know what to use hoestly. I didnt care about the scrathces so i just used the screw drivers. if you need the stock bracket after you get it out there is soecial tool that will make removing those screws alot easier. same you about an hour in a half. if you dont care about the stock radio drill the heads out and it will come out like butter. you can Pm me if you need more i just did it my self
mikeg75
Nov 30, 2015 05:12 PM
