MEVI or some Aftermarket VI on a 5th gen??
Old Apr 8, 2005 | 11:45 AM
2k1maxgle's Avatar
Took a looksy at my VI on my 01...and its broken, like most 5th gens with some mileage on them. Havent done the fix yet, waiting to see if maybe theres a more permanent fix out there than the JB weld fix. Until then, how impossible is it to use MEVI or some other VI on the 00-01 5th gen?? I know there was a 4th gen that used the 00-01 VI so how bout the reverse, an 00-01 using MEVI like most of the 4th geners?? Just pondering some new thoughts....anyone tried it??
Old Apr 8, 2005 | 12:47 PM
mingo's Avatar
yeah i always wondered why the 4th gen ppl don't get a 5th gen vias instead of a mevi, alot easier to get a hold of. and then i wondered what you are wondering.
Old Apr 8, 2005 | 12:53 PM
NmexMAX's Avatar
dot dot dot ...
mingo, because we ASSumed it wouldn't fit, then someone tried it and we are all now.
You have 4 options, some realistic, some not.
1) Fix it using JB weld fix
2) Take out the powervalve, not easy.
3) Get a new 00-01 IM and put it on, direct bolt on
4) Custom fabricte a MEVI on there
Another option .. Search
Th 00Vi is better than a MEVI, dyno proven, but it's not a direct bolt on from a 5-4g, or vice versa.
Old Apr 8, 2005 | 12:56 PM
Kevlo911's Avatar
Kevlo for President
You would have to be beyond stupid to install MEVI on a DE-K.
Old Apr 8, 2005 | 01:02 PM
NmexMAX's Avatar
dot dot dot ...
He's right
Old Apr 8, 2005 | 05:26 PM
mingo's Avatar
now i have another question, will the vq35 manifold fit on 2k maximas? because i knwo that the fourth and 00-01 maximas have the same part numbers for the heads, but the 02+ has a different part number for the heads..
Old Apr 8, 2005 | 07:15 PM
2k1maxgle's Avatar
I realize this, but there is obviously a problem with the 00-01 VI...fixing it is only temporary, gettting a whole new manifold is only temporary because the same thing will happen again over a short period of time.
Old Apr 8, 2005 | 10:57 PM
carabuser's Avatar
62K - hasn't happen. You never know if it's gonna happen. Depends on your driving style too
Old Apr 8, 2005 | 11:05 PM
mingo's Avatar
yeah, i have 114k on my car, just pulled the vias out and it's fine. u really never know
Old Apr 8, 2005 | 11:46 PM
scopium
the VIAS problem is mostly on some early 00 models.. i think nissan fixed it for 2001
Old Apr 9, 2005 | 05:57 AM
Ammi's Avatar
350 Detroit Muscle
I should check mine
Old Apr 9, 2005 | 08:36 AM
ChromeSE5's Avatar
i don't know if i read correctly on another VIAS thread and other 3.0 vs. 3.5 gens, but isnt the 3.0 top end superior that the 3.5? I just want to clear this up for myself.
Old Apr 9, 2005 | 08:52 AM
GBAUER's Avatar
If you look at the all motor forums, there are guys putting the 3.5 top end on the 3.0 motors. Why do you think they would do this?
....Ok, I know, I'll answer it myself: the 3.5 top ends are designed to allow more air flow due to the higher displacement engine.
Old Apr 9, 2005 | 10:05 AM
Kevlo911's Avatar
Kevlo for President
I have not read about anyones 00vi breaking after the JB Weld fix. I do not browse hte 5th gen forums as much as I do the 4th gens, but I have yet to see one one break after the JB Weld.
I did the JB Weld fix to my manifold even though it was 100% perfect.
Old Apr 9, 2005 | 10:51 AM
mingo's Avatar
my max was one of the first batch 5th gens..
i think it's either you get one that has plenty of problems or u don't. it's real inconsistant. i hear alot of 5.5gens having random issues too, some do some don't
Old Apr 9, 2005 | 03:25 PM
Larrio Motors's Avatar
Boss Chen Industries
i doubt the 3.5 IM will fit, the lower IM on the 3.5 is a whole lot different compared to the 3.0's.
Old Apr 9, 2005 | 05:15 PM
SPiG's Avatar
SomePsychoGuy
The 3.5 heads have a different Lower IM pattern. So this is pretty much a no.
Installing a MEVI would be stupid. NO.
JB Weld is easy, cheap, and will last forever if you do it right. Put the spring in the JB weld. let it sit overnight, and you will have not problems.
BTW There is no such thing as an aftermarket Variable Intake manifold. Every aftermarket IM I have seen is single runner. It takes too much research to get one right. Not only that but maximas at this point have no aftermarket IMs available. All of them are OEM, The 4th gen USIM, MEVI, 00VI or -k, and the 02-03.
Old Apr 9, 2005 | 06:18 PM
GreenSeMax's Avatar
121k and counting, no issues yet. I checked it the other day, and I make sure to open it up to hear it all the time.
MAXSE5SPD
Sep 17, 2022 04:00 AM
BkGreen97
Apr 2, 2016 05:47 AM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
