Struts and Springs
Old Apr 8, 2005 | 11:00 PM
Blkmax2k1's Avatar
Struts and Springs
I like the Tokito HP series over the Illumina series simply because I'm to lazy to adjust them so why bother. I have Stock wheels now with 235-45-17 tires so i have a bigger gap than before. What would be a better fit the progress springs which lower 1.7 and 1.5 or the Tein Stech which lower 2.2 and 1.6. I saw the other post about the 19 inch rims but I'm wondering about stock wheels. I want to illiminate as much wheel gap as possible. Will the Tein Stech rub?
Old Apr 8, 2005 | 11:07 PM
XGaSpAcHo
you should consider what type of ride you want after your suspension upgrade. from what i've read tokiko hp blues are a rougher ride than illuminas. as far as the springs you have to consider the same thing.
check this site out to get some info: http://www.innerbean.com/housecor/sp..._decision.html
Old Apr 8, 2005 | 11:13 PM
Blkmax2k1's Avatar
ok thanks for the site. If thats true about the struts than i would rather get the Illuminas but as far as the ride with the springs. I'll sacrifice some comfort to take out that gap.
Old Apr 8, 2005 | 11:19 PM
crispykid717's Avatar
Bigger than Jesus
I would go with the Illuminas. You are to lazy to adjust them? If you can open your hood and turn a screwdriver you can adjust them. It really is that easy. Trust me, I am a fellow lazy person. They are better because you can match them to match the spring rate of whatever springs you decide on. That way you get the best ride. As far as springs, I have Tein H-techs. They offer a comfortable ride and a good looking drop.
Old Apr 9, 2005 | 09:07 AM
Blkmax2k1's Avatar
Thanks alot for the info crisp. Are the koni adjustable worth the extra 50$ over the Illuminas. I don't know much about these. I had Hor springs with Boge turbo gas on my VW and that rode pretty good. The rear aren't adjustable?
Old Apr 9, 2005 | 09:48 AM
PaulyPoTz's Avatar
i just got my Hps put in yesterday...imo opinion the ride is about the same as stock maybe slightly stiffer over bumps and the handeling is 100X better...take turn at 30-35 with ease and much miuch less body roll... i love it
Old Apr 9, 2005 | 10:36 AM
Blkmax2k1's Avatar
pauly, what kind of springs?
Old Apr 9, 2005 | 05:23 PM
maximized2
Tein s tech with kyb struts is a real rough ride, just installed it 2 hrs ago and holy moly every dip and bump in the road is felt!
Old Apr 9, 2005 | 05:40 PM
NYPD-Arnold's Avatar
Z
Umm..Struts don't decrease body roll much if at all. That's the spring's job.
Old Apr 9, 2005 | 10:59 PM
Blkmax2k1's Avatar
anyone else out there with Tein s tech springs?
Old Apr 10, 2005 | 12:48 AM
Blkmax2k1's Avatar
I saw some pics from that site and it was very helpful. The progress springs look like an even drop all around and seem to lower more in the back than the Stechs. How are the ride dif between the 2. I've been reading alot of people complaining about the Stechs but nothing so far from the progress users. Are the progress as harsh as the Stechs?
Old Apr 10, 2005 | 12:18 PM
2K3MAX2NV's Avatar
"tse-tse fly"
I have Hp's and Blues and the ride quality isnt the same but a good even drop and good handling with the FSTB and RSB
Old Apr 10, 2005 | 08:32 PM
Puppetmaster's Avatar
No, they aren't as harsh. I have Progress/HPs and it rides nicely.... 7.5 out of 10 with 10 being stock....
Do a search for more threads on Progress springs if ya want more feedback... many others, including myself, have commented on em in the past...
Here's a pic of my drop:
And there are more here:
http://www.cardomain.com/memberpage/694087/3
Old Apr 10, 2005 | 08:56 PM
ghostrider17's Avatar
Progress is likely the most even drop without going to Coilovers, although mine still sits a smidge higher in front than back.
On rough pavement- I will not say the Progress springs are comfortable - you feel it all.....but they handle damn nice of smooth pavement and fast sweepers.
I would consider H&R's if I was to switch to a similar spring combo, while gaining back some everyday driveability and comfort.
gr
Old Apr 10, 2005 | 08:58 PM
oh - and stay away from the Konis. Although I'm not convinced of the durability of the illuminas yet.
I have about 17k on mine, and they're doing ok.
Old Apr 11, 2005 | 05:31 AM
I'd agree with that....
Old Apr 11, 2005 | 05:39 AM
Z
I'd argue that Maxspeeds are the most even of all drops and avoid the infamous "rear-sag" look other springs can create (Yes, I know that it's not really sag, that's why I said "look"). H-Tech's do a good job of a clean even look, as well.
Old Apr 11, 2005 | 06:12 AM
PaulyPoTz's Avatar
I actully kept my stock se springs on and trust me theres a noticable difference in body roll and handeling but changing ur springs will give u even less body roll for a dramatic difference
Old Apr 11, 2005 | 10:32 AM
pull10k's Avatar
Tire wear VS drop
I'm ponying up for some Illuminas. I'm not sure which way to go with springs. How badly does your tire wear change with the drop? (Camber changes dramatically) Any helpful hints or suggestions.
I can deal with the 4x4 effect I just want handling without burning through expensive tires.
PS I also am already doing a front strut brace and the stillen sway in the rear.
Old Apr 11, 2005 | 11:02 AM
To my knowledge, and also in my experience - there are no adverse effects on tire wear when dropping. If anything, you'll experience longer tire life due to better grip, and spring/strut performance.
Just make sure you get an alignment after you install the new springs or you WILL have uneven wear due to camber issues.
however, you will tend to want to push the limits of the handling in the corners since it's so damn fun!!
This will probably tend to wear your tires-out faster than before.....
Springs are a VERY subjective choice. Do your homework, and you'll figure it out. Best way to decide is to sample others' rides.
gr
Old Apr 11, 2005 | 11:07 AM
pull10k's Avatar
Thanks for the reply. Another question, is there enough camber adjustment in the suspension if I drop it 1.2 or so. Or do I need aftermarket camber adjustment plates?
Old Apr 11, 2005 | 11:11 AM
I don't know much about adjusting camber in these cars, but I do know that a 1.2" drop should NOT need addt'l plates or adjustment.
Just an alignment, and you'll be fine.
gr
Old Apr 11, 2005 | 08:15 PM
Not on struts/springs combos for the Max... none of em drop it low enough.... maybe coilovers....
MaxLvr21
Oct 17, 2015 12:11 PM
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
