Need help with blinker (after 2k3 headlight upgrade)
Old Apr 11, 2005 | 08:07 AM
Sammzway's Avatar
Well, I finally bought 2k3 headlights off another orger (BrandonSE). Last week we've installed the headlights (thanks brandon), everything is fine and dandy except one thing. For some weird reason, the driver side blinker blinker isn't working, and when I put on the left turn singnal (driver side) the blinker blinks twice as fast. The right turn signal works fine. When the left turn signal is on, the rear blinks twice as fast but the front one does not blink. I don't understand why, all the wirings were done correctly because when Brandon finished installing we double checked all the lights and blinker. It started happening the following day. Anyone had similar problem or have any suggestion?
Old Apr 11, 2005 | 11:54 AM
Sammzway's Avatar
1 2 3 , 3 2 1
Old Apr 11, 2005 | 12:05 PM
2kprlmax's Avatar
stupid answer but did you check to see if the light was blown out. Sometimes that may be the cause. If not I would recheck the cabling on te one that is working with the one that is not .
Old Apr 11, 2005 | 12:10 PM
Sammzway's Avatar
Yes, i've checked and the light bulb is fine, becuz if i take out the bulb and put it on the other side, it works fine.
Old Apr 11, 2005 | 12:11 PM
2kprlmax's Avatar
I would say recheck your cabling there is probably something loose or missing a connection somewhere
doctorpullit
Oct 28, 2019 10:58 PM
Fbana41
Aug 29, 2016 12:18 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Noela
Sep 26, 2015 08:22 AM
