When I floor it
Old Apr 15, 2005 | 07:49 AM
xplosive9z's Avatar
When I floor it
When I floor it, the car SHOULD usually start to zoom... but for some reason lately it accelerates REALLY SLOWLY (when I floor it)... its basically like, the RPM's shoot up and I can hear the engine getting loud, but the car doesn't move as fast...
Example... If I'm doing anywhere between 25-40mph, and I floor it, it should grab and just start flying down the road... Same issue on the highway, If I'm doing 70-85mph, and I floor it, it doesnt feel like its shooting out even though I can hear it...
But vice versa... if I push the pedal half way down, I can feel the car grab and then just shoot like a rubberband...
It's really scary when I floor it on the highway trying to switch lanes or merge.
Ideas or thoughts? Is there something I can do to fix it or help it out by doing anything?
I have a 00 Max. Auto GLE, Cold Air Intake, 128k miles.
Thanks, Ni.
Old Apr 15, 2005 | 08:01 AM
OhOhMax's Avatar
Trans is most likely slipping, getting ready to need a rebuild.
Old Apr 15, 2005 | 08:09 AM
xplosive9z's Avatar
Ouch... I'm gonna be dropping alot of moola right?!?! How much do you think (est.)?
Could it be anything else besides the slippage?
Old Apr 15, 2005 | 08:37 AM
LA02MAX's Avatar
so the RPMs are still climbing..its just the car not moving? if so, then it is most likely a slipping tranny...
Old Apr 15, 2005 | 08:42 AM
xplosive9z's Avatar
No the car IS moving... it's just that I don't feel that hard grab and speed.
Old Apr 15, 2005 | 08:47 AM
LA02MAX's Avatar
sorry, i didnt meant that it wasnt moving, i just meant it wasnt MOVING...(like they're supposed to) ... my guess, in this case, is the tranny...
Old Apr 15, 2005 | 06:57 PM
DonGfun's Avatar
VW = 30 MPG
I bought a used trany for $650 shipped and my shop put it in for $500 ... some may say it is a big risk but a rebuild would have cost 2k ... so I saved $800+ on a car with 120k miles.
Old Apr 15, 2005 | 07:06 PM
panda_1's Avatar
friend of mine bought adn installed a factory rebuilt tranny for 1900 and like 3 hours of labor. the thing is our cars dont usually pull harder if floored, they usually pull more when given throttle lil by lil.
Old Apr 15, 2005 | 07:16 PM
NYPD-Arnold's Avatar
Z
Yeah, your tranny is shot.
Old Apr 15, 2005 | 07:55 PM
Rob01ski
Hold on maybe its not shot, did you have the tranny oil changed recently and never before if so you might wanna let it set in, but you may also need to change the tranny oil
have it flushed completly, if that doesnt work the your tranny is most likely shot
ps if its shot why not just spend a little extra and get a 5spd dropped in
Old Apr 15, 2005 | 08:52 PM
MxdOut97's Avatar
i had the same problem i think. my mass air flow sensor was basically sandblasted cuz there was a problem with my air filter, so it was all messed up. so, i got a new one and the car was reborn. pissed me off for a long time, thought i needed a new tranny, but it ended up not bein that. im not sure if your having the same problem. the car was fine undder about 3k rpm, then after that it seemed like the tranny was slipping. also, the car sometimes shut down. hope this helps.
Old Apr 16, 2005 | 06:24 AM
csvemuru's Avatar
My experience is similar to MxdOut97 and have the 2000 Green SE. I was pretty sure that it was the transmission before replacing the MAF. Suggest that you look into that.
Old Apr 16, 2005 | 08:50 AM
2000 Maximus's Avatar
Yea i would try to replace the MAF first, then maybe the tranny fluid.
If those dont work out, then your gonna need a new tranny.
Good luck though
Old Apr 16, 2005 | 01:32 PM
MxdOut97's Avatar
yea def. go for the MAF first, cost me like 300 + install i think, shouldnt be the tranny tho, 128k isnt that bad, ive seen max's with 400+k on them with just regular maintenance
Old Apr 17, 2005 | 06:48 PM
BLUEMAX01SE's Avatar
that hard grab your looking for is still in the car, its mainly from the dohc in the vq, u may need to catch it at a perfect rpm, because your trans is programed (learned thru the ecu) to how you drive your car. ur cams r gonna help your rpm's shoot up and then the car will pull thru. try to not just womp on the pedal , but as you're doin lets say 40mph, then step on the gas about an inch or so, you'll feel a kick and then give it more gas as you push the pedal down n then you should feel another kick. it's how u drive your car, you'll understand once u try this.
Old Apr 17, 2005 | 08:03 PM
MxdOut97's Avatar
i dont think that solves his problem
you should be able to stomp on the gas and have no problem with the tranny or acceleration
Old Apr 18, 2005 | 06:36 AM
ramanog1's Avatar
I am having a similar problem, when my car is cold and I'm driving it holds in first for a little too long and then jumps into the next gear. It is a 2000 gle auto with 87,000 miles on it. Has a new MAF and a trans fluid change. After I drive the car for a few miles the problem does go away.
Old Apr 18, 2005 | 06:43 AM
SoonerFan's Avatar
Cletus
it might just be the transmission control module (TCM)
there is a TSB for it. basically the computer isnt telling the tranny when to make shifts so it delays everything.
i had to replace my TCM a few months ago. if my car ends up being totaled up going to pull out the new upgraded TCM and put the old one back in. i will be selling it (value is $700 but i'll sell it for less)
Old Apr 18, 2005 | 06:44 AM
SoonerFan's Avatar
Cletus
thats definetly the TCM. exact same problem i had. if you dont fix the problem it will wear the tranny out like it did mine
Old Apr 18, 2005 | 09:59 AM
Rob01ski
Could be just because the trannys cold, and he has new fluid in it that need to wear in there, i think just dont floor the car when the trannys cold drive nicely at first to let it warm up and then DRIVE IT LIKE YOU STOLE IT.
uttadms31
Sep 30, 2015 05:24 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
Domf3
Sep 22, 2015 03:05 PM
