question - "Service engine soon" indicator
Old May 9, 2001 | 05:34 PM
madmax2000's Avatar
how does the "Service engine soon" indicator work?
mine came on about the correct time my oil change was due, but i got the oil change done, and it still hasnt gone off..
thanks
Old May 9, 2001 | 05:41 PM
unrealii's Avatar
I'd sugest taking it to a Stealer. You have warranty, right?!? If possible, you might want to check the maf or your O2 sensors.
Old May 9, 2001 | 05:43 PM
y2kse's Avatar
thanks
I've never heard of a Check Engine light coming on because an oil change is due. That certainly hasn't been my experience. I've got 13,500 miles on my SE and my wife has over 26,000 miles on her GXE. Neither of our cars have ever thrown a Check Engine light. I'd suspect that something else is going on.
If it was my car, I'd take it to the dealer immediately and have them diagnose the error code. If you don't want to do that, you might try resetting your ECM by removing the ground cable from your battery for a couple of hours. Then reconnect your battery and see if the Check Engine light goes away. If it doesn't, take your car into your dealer and let them figure out what's going on.
Old May 9, 2001 | 05:45 PM
madmax2000's Avatar
well, it has come on once before but went off by itself soon after the oil change (not done at a dealer)
so i was wodnering why it didnt this time..
max 2k SE, gray lustre, 5-sp, no mods - yet
Old May 9, 2001 | 06:04 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Hi there! Did you know you can enter your car's information into your sig so that you won't have to type it each time? Click on profile in the upper right corner.
Old May 9, 2001 | 06:05 PM
UMD_MaxSE's Avatar
Got Bent?
that light has nothing to do with mileage or oil changes....something is wrong it to the dealer to get it checked out.....
Old May 9, 2001 | 06:10 PM
y2kse's Avatar
yup i will.. thanks guys
OK. Even if your Check Engine light isn't on right now, your ECM may have stored the error code. Have your dealer run an ECM diagnostic with the Consult II.
Old May 9, 2001 | 06:12 PM
madmax2000's Avatar
ya was just too lazy did it now
madmax2000's Avatar
Originally posted by y2kse
Agreed. Take it in now!
Old May 9, 2001 | 06:17 PM
StreetMax
I know this is strange, but my service engine light just came on too. I have an appointment to get it look at this week. Do you think they will give me any problem since I have JWT popcharger?
Thanks,
Old May 9, 2001 | 06:24 PM
UMD_MaxSE's Avatar
Got Bent?
Thanks,
I am going to say that they will give you trouble over it.....take it off and see if the light goes away. If it is still there, go to the dealer with stock air box in place..
conansriver
Sep 3, 2015 06:38 AM
raffivegas
Aug 23, 2015 09:54 PM
Justinmc760
Aug 23, 2015 03:10 AM
Flores94
Aug 11, 2015 12:53 PM
