Maxima 2000 GLE Shock Sturts
Old Apr 18, 2005 | 12:18 PM
Coby099's Avatar
Hey guys,
I need help once again.... everytime I hit a bump I hear a loud boom noise in the front shock struts.. I believe I need to change them - my GLE has 79K miles on it. I went to the dealer and they told me that it will cost $256 for each strut ... I just need the 2 in the front. It is very expensive to go the dealer. Do you know what other good brands I could put instead of the one from the dealer. I believe my shocks are fine its just the struts cause one mechani told me that they need to be replaced. If anyone can help me by giving a contact where I can purchase good struts (equivalent to the OEM or better - I would really appreciate it. Thanks for all help guys.
Rami
Old Apr 18, 2005 | 12:31 PM
AuAltima3.5's Avatar
Shocks and Struts are both suspension components, but only one can be at each wheel. So the front of your max has two struts, one per wheel, and two shocks for the back (per wheel, again).
If you are sure your two struts are bad, there are a number of replacements, and it depends how much you want to spend on them. Hopefully someone else can point to some good struts.
Old Apr 18, 2005 | 12:39 PM
NismoMaxm's Avatar
You wanna buy aftermarket struts. I would also suggest that you lower your car along with putting on new struts. The ride with be wicked nice with a firm strut and nice drop. Prevent body roll and what not. There are alot of spring and alot of struts. I have Tein S-tech springs on Koni Struts. Nice firm ride. I really want to buy Tokico Illuminas though. Pricey but wicked nice. This is the right place to get the information you are looking for man. Good Luck.
Old Apr 18, 2005 | 12:49 PM
Coby099's Avatar
Thanks for the advise.... I am not looking to lower the car, I wanna keep the car stock. What kind of front struts should i get and how much am I looking to spend on them????... the car is a GLE.
Rami
Old Apr 18, 2005 | 12:55 PM
NismoMaxm's Avatar
Looking to spend?whats your price range?
ok well even if you dont want to lower it, you can get Tokicos,Konis,weapon R, Edibach... Oh man theres tons. I heard a very lot of good about the tokicos. If you check in the sticky for links on places to buy parts. There are tons of places to compare out prices on struts. Im sure you will get many more responses in here.
Check here:
http://forums.maxima.org/showthread.php?t=29750
Old Apr 18, 2005 | 01:19 PM
SgtSchulze's Avatar
Burn Dust. Eat my rubber.
I have a set with 30k on them from when I lowered my car if you want a good price. PM me.
Old Apr 18, 2005 | 01:23 PM
Coby099's Avatar
Are the Tokicos as good as the Stock Nissan ones.... Will I have the same smooth ride? And how much would it cost me to get to 2 front struts for my 2000 GLE Maxima?
Old Apr 18, 2005 | 01:27 PM
NismoMaxm's Avatar
its going to be a stiffer ride most likely, but the ride quality should be jsut as good.The Tokico HP's on custom enterprise are 349 for all four, 2 front and 2 rear. and the Tokico illuminas are 499 for all four. cehck them out,
Here:
http://www.customenterprise.com/view.../vts/design017
Old Apr 18, 2005 | 01:32 PM
Coby099's Avatar
I am looking for the same exact ride that I have now... I believe I have the original ones in there now. Do you think I should go with the Dealer ones or am I getting ripped off?
Old Apr 18, 2005 | 01:37 PM
NismoMaxm's Avatar
How much is it to buy the OEM ones??
ooops i stand correct about 500, then they have to install at another rate. Im not sure what you should do man. All i know is that alot of guys take out the OEM for lasting reasons and for ride quality.
Old Apr 18, 2005 | 01:39 PM
Coby099's Avatar
$256 each - one for the front right and one for the front left
Old Apr 18, 2005 | 01:41 PM
NismoMaxm's Avatar
I would replace all four with aftermarket, but lets see what some other guys have to say. they know a lot more then me im sure.
Old Apr 18, 2005 | 01:50 PM
SgtSchulze's Avatar
With OEM Springs etc.... it's pretty hard to justify spending a bunch more money on aftermarkets. But for $250 each for dealer OEM thats a little pricy. I'll sell you my used OEM struts for $150 for all four!
Old Apr 18, 2005 | 01:51 PM
NismoMaxm's Avatar
and you said they had low miles correct? about 30k if i recall right so Coby you might wanna do that, get some pics of the struts so you can see the shape, make sure you can see all the sides of the struts.Then you decide.
Old Apr 18, 2005 | 02:23 PM
NewLoveI30's Avatar
I really think the ride would improve If you switch to the Tokico Illuminas. They are easily adjustable so you can tune the ride to your liking.
If you stay with the stock springs the ride will still be super smooth but the higher quality Illuminas will give you more control and less bouncing around.
Old Apr 18, 2005 | 02:57 PM
NismoMaxm's Avatar
You used the words i was looking for man. hahaha.
Old Apr 18, 2005 | 05:54 PM
Coby099's Avatar
I just feel that $256 bucks for each front strut is kinda steap and that im getting ripped off - so I guess the best thing for me to do is get the Stock OEM struts from the nissan dealer for the smoothest ride?
Old Apr 18, 2005 | 05:55 PM
Coby099's Avatar
how much miles does the struts have.... that u wanna sell to me for 150 bucks....what condition are they in ???
Old Apr 18, 2005 | 06:08 PM
NismoMaxm's Avatar
i dunno how much nissan charges, but you can check courtesy nissan and see how much they cost. i think the best bet would be the illuminas cause theyll last the longest and they are easily adjustable for ride stabilty and ride hardness. I looked into them a little bit more and for the money it might cost you to get two new oem nissan struts you could get all four illuminas for 499. So hhmm, check out courtesy.
Old Apr 18, 2005 | 06:32 PM
SgtSchulze's Avatar
They are in good condition. I had my car lowered on Tein H-Techs and Illuminas last spring and my car had about 30k on it. Right now my odometer says 42k. I can get pictures, receipts, etc... if you want to prove that they were that old.
Click Here for a little proof
Old Apr 18, 2005 | 08:41 PM
Adi G. Wijaya's Avatar
You got PM. I have stock strut for sale also. It will be removed this weekend. Currently i have 24000 miles on it. I will take a picture of the odometer tomorrow for the proof if you want.
Just give me an offer.
Old Apr 19, 2005 | 08:29 AM
Coby099's Avatar
How much do you want to sell them to me for? What year is your maxima and are they GLE struts? I am willing to purchase used ones that have such low miles on them. So let me know how much ! and maybe we can arrange something!
Rami
Old Apr 19, 2005 | 08:31 AM
Coby099's Avatar
Can you give me a slighty better price on them?
Old Apr 19, 2005 | 10:02 AM
Coby099's Avatar
Can you send me some pic's?
Old Apr 19, 2005 | 01:25 PM
Coby099's Avatar
Anybody?????
Old Apr 19, 2005 | 01:43 PM
SgtSchulze's Avatar
Check back in a hour or so for some pics.
I sent you a PM on the price.
Click Here for Pix
Old Apr 19, 2005 | 04:56 PM
00MAXI's Avatar
Get the KYB GR-2s. They are pretty cheap and the ride will still be nice but just not as floaty.
Old Apr 19, 2005 | 11:44 PM
hi,
I will sell it to you $140 with free shipping (O.B.O.). Mine is 2001 SE, it is the same strut between SE and GLE. I will remove it this weekend. Let me know if you are still interested.
Guarantee not to be dead on arival. It is still in a perfect condition.
I accept paypal, money order, etc.
Old Apr 19, 2005 | 11:59 PM
PEARLDIAMOND's Avatar
Does anyone know where i can get an AE kit for an 01 maxima and how much it will cost.
Old Apr 20, 2005 | 06:37 AM
Coby099's Avatar
Click Here for Pix
Does anyone here know how I can check my Private Messages.... I dont know how to do it :-(
Old Apr 20, 2005 | 06:41 AM
ThunderMaxi's Avatar
Rami
I am curious also... I teach school and we have humongous speed bumps to keep parents from doing 50 down the driveway... I have heard my car scrape once or twice hitting the bumps...
Old Apr 20, 2005 | 07:48 AM
SgtSchulze's Avatar
Top right of the forum board...not the header..but the forum itself. Click the link under your name.
Old Apr 20, 2005 | 08:39 AM
turbo_gg's Avatar
#1.) Don't by two Nissan shocks for $500 when you can get 4 aftermarket
shocks for the same price (give or take a few $$). You will eventually
need to replace the rear shocks, then you'll have to spend even more
money. It would be crazy to spend $700-800 on OEM shocks.
#2.) Buy aftermarket shocks. Illumina (made by Tokico) are adjustable, so
the turn of a dial you can adjust the ride the way you want it. I have
mine set on #2 in front, and #2 in back (the shocks are adjustable
from a setting of 1 thru 5, 1=soft, 5=firm). Aftermarket shocks
give you far better control, and ride, then the OEM Nissan shocks.
#3.) Don't replace the front shocks only if you go aftermarket shocks, it is
always better to replace all four. That way the car's suspension is
equally balanced, providing much better and safer handling.
Old Apr 20, 2005 | 10:03 AM
Coby099's Avatar
Anybody Know how to check a PM?
Old Apr 20, 2005 | 10:41 AM
Coby099's Avatar
Anybody know how to check a PM -- HELP!
Old Apr 20, 2005 | 10:54 AM
SgtSchulze's Avatar
See above........or send me an email @ cschulze@artromick.com
Old Apr 20, 2005 | 11:16 AM
Coby099's Avatar
Hey thanks for the advise !!!! I dont need to change the shocks in the front - all I need to change is the 2 front struts..... do you still think I should get the Tokico ones? How much will I spent on them and where can I get them?
Old Apr 20, 2005 | 01:08 PM
Coby099's Avatar
do we have a deal????
Old Apr 20, 2005 | 01:10 PM
SgtSchulze's Avatar
Yeah.....email me!
CRizz
41
Jun 7, 2021 05:42 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
jholley
Aug 11, 2015 09:38 AM
Greenmaxspeed
Aug 8, 2015 12:39 PM
niZ
Aug 7, 2015 10:18 PM
