Owned by the FSTB
Old Apr 18, 2005 | 06:56 PM
bigsherv's Avatar
Owned by the FSTB
Man, i bought a FSTB from nite-stalker and my hood won't close? How do I fix this. I have read this before but googled did not give me anything relevant. Please help!
He said it is a Bomz FSTB. Man it got it to finally fit and then whamo, hood won't close.
Old Apr 18, 2005 | 07:06 PM
Maximax2's Avatar
Try adjusting it - sounds like you have it up too high. I have the BOMZ too, and it adjusts by taking it off, then screwing in the end pieces a couple of turns (each). That should lower it enough to clear the hood - it's a very close adjustment between clearing the hood and clearing the engine (mine barely hits when you hit the gas in reverse - otherwise clear all the time).
Peace
Old Apr 18, 2005 | 07:11 PM
bigsherv's Avatar
i got it to fit. I just messed with it a bunch. How tightshoudl everything be? I hand tightened it and then gave it a quarter turn with a wrench. WHat about the nuts on the bar. I tightened those up too but no too tight.
Old Apr 18, 2005 | 07:13 PM
Maximax2's Avatar
First, there's supposed to be a little tension on the bar (i.e. it's pushing against the strut towers, just a little).
I tightened the nuts (on the bar) a lot, but you don't have to haul on them. Don't really know what the torque spec is.
Old Apr 18, 2005 | 07:38 PM
NisMoN00B's Avatar
+Cru OG
the torque specs are 36-40 ft. lbs. I highly suggest using a torque wrench for tightening or you'll end up stripping the strut threads when its under load.
Old Apr 18, 2005 | 07:50 PM
icewake's Avatar
did you have any real noticeable differences after you installed the FSTB? I have one on the way and wasn't really sure how much it would help.
Old Apr 18, 2005 | 07:51 PM
XGaSpAcHo
if you dont have a torque wrench take it to a mechanic. they'll charge you $20-$30 but you'll know it's on right.
Old Apr 18, 2005 | 08:00 PM
NisMoN00B's Avatar
+Cru OG
the car feels a little, and i emphasize LITTLE stiffer during cornering (60mph, long sweep corner). I've read here that installing RSBs is where you'll notice the most in handling.
$30 for a mechanic to torque the bolts?! for that amount, i'd run to autozone and buy me one.
Old Apr 18, 2005 | 08:04 PM
icewake's Avatar
Thanks. How hard would it be to install a RSB and how much would it be?
Old Apr 18, 2005 | 08:11 PM
NisMoN00B's Avatar
+Cru OG
I had a buddy help me install the RSB for about an hour or so, of course, this included taking tequila shots every three turns of the wrench or so.
The Progress RSB i bought off custommaxima.com was $135. I don't know what the current price is. Addco also makes RSB but i don't know the price or the applications.
Old Apr 18, 2005 | 08:30 PM
icewake's Avatar
don't hate me, but where exactly does the RSB go and what tools were required?
Old Apr 18, 2005 | 08:37 PM
Puppetmaster's Avatar
http://www.greghome.com/Greg%27s%20G...StillenRSB.htm
Old Apr 18, 2005 | 08:42 PM
NisMoN00B's Avatar
+Cru OG
To actually understand this, go here http://www.moodym.com/maxima/tech/addcorsb.html
Old Apr 18, 2005 | 08:52 PM
icewake's Avatar
That help alot more. Thanks.
Old Apr 18, 2005 | 09:01 PM
icewake's Avatar
what would be better......a rear sway bar or a rear strut bar?
Old Apr 18, 2005 | 09:38 PM
RSB... time for you to do some homework...
https://maxima.org/faq-5-Suspension.html
Also, use this to search for old discussions on the rear sway bar and strut bar....
Old Apr 18, 2005 | 11:27 PM
bigsherv's Avatar
Who here had the FSTB professionally installed?
Old Apr 19, 2005 | 12:04 AM
spiromax's Avatar
Seoul Man
Whoever it was probably won't speak up for fear of being beaten to death with a torque wrench.
Old Apr 19, 2005 | 12:10 AM
panda_1's Avatar
not me!!! my torque wrench owns me!!
user 11122324
42
Jul 18, 2022 03:35 PM
doctorpullit
Mar 29, 2016 11:08 AM
fx4five
Oct 1, 2015 04:58 AM
NERDJUSTBNME
Sep 30, 2015 03:20 PM
Socalstillen
Sep 20, 2015 11:46 PM
