Spec on STock 17" Wheels!!!!
May 10, 2001 | 07:49 PM
Hi, does anyone know the offset and bolt-pattern on Stock 2k maxima 17" wheels?
Tim
May 10, 2001 | 09:12 PM
Quote:
Tim
Help guys...Please
May 10, 2001 | 09:30 PM
do a search
May 10, 2001 | 09:50 PM
Quote:
Originally posted by DooBall
do a search
he probally already did, not many people have offsets..sorry wustylez, i kant help, i dont really even know wut a offset is.
May 10, 2001 | 10:06 PM
Quote:
Is it in the manual?
May 10, 2001 | 10:48 PM
i doubt it. sorry dude, try the general forum, i think i remember someone with offsets.. but kant recall.
May 10, 2001 | 11:01 PM
The stock offset is 39mm. You can use wheels with offsets ranging from 35mm-43mm; 38mm and 40mm offsets are common, so that's what I'd stick to. The bolt pattern is 114.3, also common. And don't forget to get 5 lug wheels!
May 10, 2001 | 11:16 PM
Quote:
Actually, on page 10-9 of my 2K1 manual, it is clearly stated that our offset is 45 mm. However, the offset for the 16" is 40 mm. Have fun!
May 10, 2001 | 11:19 PM
The offset is the distance between the hub mounting surface (inside back surface of wheel) to the centerline of the rim.
39mm offset means that the surface the rim mounts on is 39mm in front of the centerline of the wheel. If this is unclear, check any tire co. website. They should have more info on offsets.
May 10, 2001 | 11:35 PM
Quote:
45mm???that seems awfully too much...so is it 39 or 45mm???
I will check my manual to see...thanx guys!
Tim
