ABS Light On
Old Apr 23, 2005 | 10:16 PM
vsamoylov
ABS Light On
Well today my abs light came on. does anybody know how to reset it? abs worked fine until today when i put the car on jacksatnds and started it and then the abs light came on. thansk for the help.
Old Apr 24, 2005 | 09:04 AM
vsamoylov
anybody have a clue?
Old Apr 24, 2005 | 09:54 AM
schernov's Avatar
Two things.
1. You might have pulled a ABS sensor wire by accident and the connection is loose - to fix that - just pull the wheels off, look on the back side of the rotor and you will see a little round sensor, with a wire going from it ... trace the wire to the connector - in the back the connector is about 18 inches to the front on the FRAME ... upfront it is closer to the control arm. Make sure all connections are good.
2. If step 1 does not fix it, you have a bad ABS sensor. Only Nissan dealer can pull that code, as it is proprietery...they will tell you exactly which sensor it is. Replacing is easy, just undo the connectory, unscrew the sensor and put one it....it looks like a spark plug boot..
Sensors are about $125 from dealer. They are mostly on back order.... but Infiniti dealers I35 sensors are the same...
Good luck.
Old Apr 24, 2005 | 02:12 PM
vsamoylov
i am going to check that. but seriously the sensor can go bad. all i did was get the car on jack stands and put it into gear and then the abs light came on. any clue how much nissan will charge me to see what the problem is?
Old Apr 24, 2005 | 02:27 PM
paralyse's Avatar
I Miss My Maxima
It may have triggered the code if all 4 wheels are off the ground and you ran the car in gear -- the ABS might get confused by seeing 4 different wheel speeds, one from each sensor, that don't match.
Or you might have broken or dislodged one of the wheel speed sensors (a toothed ring, as above) when you put the car up into the air.
Depending on your dealer if you're outa warranty probably $60 to $80 to pull the codes.
Old Apr 24, 2005 | 03:56 PM
vsamoylov
well i only had the front wheels off the gound. i was just wondering if there was a way to reset it or maybe it will go away on its on after a while? like it will see that everythign is normal after driving? i just want that stupid light to go away.
Old Apr 24, 2005 | 04:49 PM
schernov's Avatar
Just taking the wheels off the ground should not do anything, I did a brake job like that...
Mine came on right after I washed the car and I thought I went too crazy with cleaning the rims and shorted something....
My dealer diagnoises everything for free so ... and then that sensor was goodwilled by nissan as I had only 65k miles on 2.5 year old car.... they did not have the sensor in stock to I had one shipped from a Pittsburgh dealer and local one put it in...then got re-imburesed by Nissan NA for the part. Later on I found out that local Infiniti dealer 30 miles away had 3 of them...
Old Apr 24, 2005 | 08:58 PM
vsamoylov
so most likely it is a sensor then? now i have to find out which one.
mvm062
Nov 30, 2020 09:00 AM
bbsitum
Sep 6, 2019 07:31 PM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
maximusrising
Sep 2, 2015 09:55 AM
